Brake problems on CJ7 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-05-2001, 11:56 AM
Hi all,
I have a 1985 CJ7 and while moving it to the driveway I gently applied the brakes and the RR tire locked up. It seems that whenever I apply the brakes the RR tires brakes more than the other three. The brakes have all been rebuilt sometime last summer and the Jeep hasn't been used that much. Anything I should look at before taking the brakes apart? Any advice would be greatly appreciated.
Thanks.
John C.
1985 CJ7
2.5" Spring lift
1" body lift
33x12.5x15
[email protected]
post #2 of (permalink) Old 09-05-2001, 12:19 PM
Re: Brake problems on CJ7
Purely a guess, but oil on the linings from a leaking axle seal can cause this problem. Better pull the drum and take a look.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #3 of (permalink) Old 10-06-2001, 10:32 PM
I thought that oil on the brakes makes the brakes that are effected useless . Anyone have any opinions on this ? Where is CJDave when we need him .
stock junky Jeep
post #4 of (permalink) Old 10-06-2001, 10:37 PM
Smokngun's Avatar
Grease/oil on brake linings changes the friction qualities of the material and they lock up or grab SEVERLY! That is the case 95% of the time with a grabbing brake. Other 5% is a mechanical failure inside the drum (ie: something fell off and is bound up in the drum). Either way, you gotta pull the drum to see. Good luck!
Mike H.
1983 CJ-7 Laredo, IT'S ALIVE!
Smokngun is offline
