Caster and Shackle Lifts - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2001, 04:10 PM
jeepfiend
There is a fellow here at work with a 92 wrangler. He is planning on installing a shackle lift. Most of the shackle lifts available are right about 1.25". Is this because any more would have negative effects on the caster and the pinion angles. What is the standard caster angle for the wranglers. For the tires to track properly, doesn't the lower joint in the knuckle need to be behind the top?
Cage Up, Wheels Down
Jeepfiend
All my Jeeps are in pieces! Except for one!!
post #2 of (permalink) Old 09-04-2001, 05:49 PM
Re: Caster and Shackle Lifts
yes the lower ball joint needs to be infront of the upper ball (I think it's called negative caster and I think it only needs to be a few degrees correct me if I'm wrong)
popazeus is offline
post #3 of (permalink) Old 09-05-2001, 12:43 AM
jeeperjohn's Avatar
Lower ball joint in front of upper is positive caster. My manual only goes to 994, but from 1987-94 it calls for 7 1/2 to 8 1/2 degree positive manual trans, 6 to 7 degree positive for autos. With the preferred settings being 8 degrees positive for manuals and 6 1/2 positive for autos. Adding length to the shackels will reduce the amount of caster.
They that can give up essential
liberty to obtain a little temporary
safety deserve neither liberty nor safety.
jeeperjohn is offline
