how hard to lift body for frame repairs? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2001, 01:46 PM Thread Starter
my frame is in need of a little tlc, so if i just losen all the body mounts, i should be able to lift the body up off the frame maybe 6 in or so to do some work, right? also, do i need to loosen all the body mounts?
thanks all
shawn
The cup isn't half full or half empty, it's just twice the size it needs to be!!!
80cj is offline
post #2 of (permalink) Old 09-04-2001, 02:10 PM
RickB's Avatar
Re: how hard to lift body for frame repairs?
To lift the body off the frame, remove all the body mount bolts. Other things to consider, brake lines, clutch linkage, wiring, steering column, radiator shroud. all these things may need to be loosened or removed depending on how much slack they currently have.
Did I forget anything?
Rick
80 CJ7
RickB is offline
post #3 of (permalink) Old 09-04-2001, 05:34 PM
Hi
I just replaced my tub its not too bad but you will have to disconnect the break lines, clutch, throttle, spedo cable and the hardest will be the steering
post #4 of (permalink) Old 09-04-2001, 06:15 PM
pontiac58's Avatar
If you are only fixing the rear end of the frame you wont need to lift the body at all. I did mine last spring without lifting the body.
http://bbs.off-road.com/wwwthreads//...view=&sb=&vc=1
check that out it shows the work we did.
Can someone please bring me a hammer my 33's just ate my fender again. Damn i need more lift.
pontiac58 is offline
post #5 of (permalink) Old 09-05-2001, 12:32 PM Thread Starter
yeah actually most of the work will be to the back end, so i'm hoping to get away with alot less work.
thanks all
shawn
80cj is offline
