I can see the light!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2001, 09:24 PM Thread Starter
gigolo's Avatar
The nv4500 is in! I just got the rest of my parts yesterday. I took a vacation day today and started at 9:00a.m. I had the bearing pressed on the new input shaft, put it on. Had the retainer machined, put it on. Rented a tranny jack, got the throwout bearing and came home and went at it. I just now got done with getting the tranny in. I still have to put in the transfer case and shifter linkages. A big thanks to all of you that contribute to the board. I rented a tool for pulling the pilot bearing thinking it might work, nope. I was really glad I had read on here about using grease to hydraulic it out. It took about 10 times, but it worked nicely. I am feeling pretty proud today, having never even done a clutch job before, much less a tranny conversion. But, at least I know it was all done right AND I know where everything is and how it's in there. Thanks to all, I seriously doubt I could have did it without the knowledge I've gained from this board! I might get to see some trails this summer after all. [img]/wwwthreads_images/icons/laugh.gif[/img]
Later
Adam
BIGJEEPTJ
A man's got to believe in something, I believe I'll have another[img]/wwwthreads_images/icons/crazy.gif[/img]
gigolo is offline
post #2 of (permalink) Old 08-31-2001, 11:18 PM
Re: I can see the light!!!
YOU GO ON WITH YOUR BAD SELF!!! I know exactly how you feel, you WILL make it, and hey, you've got an entire 3 day weekend to get it going.
A piece of advice. Before you put the transfer case in, I would turn it over a couple of times, just to make sure that your clutch deck and fork are properly clearanced. If it's not, you will hear a "very bad sound", easily recognizable from 150 yards, stop where you are. If it sounds normal, proceed with the x-fer. You will probably want to leave the orange plug in the rear of the tranny just in case (test should be done with trany in neutral, and test engaging/disengaging clutch.
What x-fer were you throwing on this thing? If it's an Atlas, you've got a little cutting, but other than that, it sounds like you have it by the short hairs.
bluseman2a is offline
post #3 of (permalink) Old 09-01-2001, 08:13 AM Thread Starter
gigolo's Avatar
I'm putting the 231 tcase back in. I did a SYE on it while it was all apart and because of the new lift. I wish I could afford an atlas right now, but this project has already killed my pocket book. Thanks for the info on the clutch, i'll do that.
Later
Adam
BIGJEEPTJ
gigolo is offline
post #4 of (permalink) Old 09-01-2001, 02:55 PM
I noticed you said he has a little cutting to do if he wants the atlas, how do you mean?? I'm thinking of putting the atlas to my nv4500 . are you meaning body wise, or someting else
JR
"Some People Live An Entire Lifetime And Wonder If They Have Ever Made A Difference, But The Marines Don't Have That Problem" R. Regan
post #5 of (permalink) Old 09-01-2001, 07:31 PM
Hey JR,
Not sure if the shifter linkages on the YJ are the same as a CJ, but when I put mine in I had to trim the tub in order to get the shifters to fit. Basically you need to notch the passenger's side of the transmission tunnel about 3-5" so the shifter's mount properly. I then had to re-fab an inspection cover to fit over the new hole.
The Atlas is very nice when used in conjunction with the NV4500, in that there are no adapters, it's just 8 studs with associated nuts. The most difficult thing about it is deciding how far you want to clock it up. I have a 1" BL, so I had the room to clock it almost horizontal.
post #6 of (permalink) Old 09-01-2001, 07:36 PM
I was just curious if you had to trim the output shaft of the 4500. I have one, and have already chewed the body up, I just wanted to know for ref.
JR
post #7 of (permalink) Old 09-01-2001, 08:01 PM
Nope, no trimming necessary, assuming the spline-count is correct (I believe that the common is 23 or 29). If the shafts fit together (# of splines), all you have to do is goop the collar with a little RTV and bolt it up.
I may be off base here, but if you have a Dodge NV4500, there shouldn't be any fitment issues at all.
