Tranny Help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-30-2001, 03:33 PM Thread Starter
Tranny Help
i need to know what fluid goes inside a 1983 CJ-7 T-5 5 speed transmission as well as the same year Dana 300. So far the contenders are GL-5, 80w-90, or Dex II. i would think one of the gear oils, but due to the confusion among some publishers, i thought i would ask the people in the trenches. Thanks for any help.
Scott...
My Rides
1979 CJ: 304, 3spd, tires, rust, miles
1989 XJ: has seen every state except Hawaii
In search of lost paths and distant locations...
MyRide is offline
post #2 of (permalink) Old 08-30-2001, 03:50 PM
Re: Tranny Help
The Dexron is an Auto tranny fluid and therefore a hydrolic fluid used where pressure is needed. The 5-speed is dealing with gears and so use the gear oil. Some t-cases use auto fluid but only the chain driven ones. If the 300 is gear driven, use the gear oil.
What's in them both now?
'88 Sahara, 4.2 that runs. The rest is getting there![img]/wwwthreads_images/icons/blush.gif[/img]
post #3 of (permalink) Old 08-30-2001, 05:52 PM
Re: Tranny Help
GL-5 is a spec for gear oil.. i.e. you would buy 80w90 GL-5 gear oil
Mark
83 CJ-7 and 76 CJ-7 with stuff
sloop is offline
post #4 of (permalink) Old 08-30-2001, 06:11 PM
Re: Tranny Help
IM pretty sure some later T5 applications ( Ford Mustangs) spec'd DexII in them also.
its a mileage thing, sacrifice a little longevity for a little gained MPG.
use gear lube in both.
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
post #5 of (permalink) Old 08-30-2001, 11:32 PM
I Do This For The Glory
JEEPN's Avatar
Re: Tranny Help
According to the Factory Service Manual, the T-5 should have "AMC/Jeep Automatic Transmission Fluid or equivalent Dexron II".
The D300 takes gear oil, 85W-90 (API GL-5).
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #6 of (permalink) Old 09-01-2001, 01:17 AM
Re: Tranny Help
Does the T-4 need dex II as well?
JeepinDoberman is offline
post #7 of (permalink) Old 09-01-2001, 07:40 AM
Re: Tranny Help
Do a search here. I wish I could give credit where credit is due, someone said "Gear lube for gears, hydraulic fluid for pressure applications". Sometimes in cold climates a T-4 or -5 will shift stiff when cold. I found a 75W-90 gear lube for those colder mornings.
Huh?
JimmyZ is offline
post #8 of (permalink) Old 09-01-2001, 09:09 AM
Raduckal's Avatar
Re: Tranny Help
Advance Adapters says to use Dextron III in their WC T-5s and T-4s. 80 to 90 wt gear oil is right for the Dana 300. I ran 80-90 in a rebuilt SR-4 and it blew in less than a year.
I'm on here so much, I have carpal tunnel reader syndrone.
Raduckal is offline
