super 35 kit - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-09-2001, 12:15 PM
super 35 kit
if i have a super 35 kit and and axle trusses will ya'll think it will hold it's an '87 with 4.2, puegot trans, and np207 t-case i will run 33x12.50 15 mud tires all i do is mud ridin' in louisiana also should i run 4.56 or 4.10 gears thanx
'87 jeep wrangler in process of building
post #2 of (permalink) Old 08-09-2001, 12:18 PM
Re: super 35 kit
I would think that with a super 35 you would be ok with 33's. However if you are going to beat on it you could break somthing. I wouldn't go any bigger than 33s. But I have heard of factory 35s holding up to 36 inch tires with no real problem.
91 YJ swaped in 4.0L 2 inch lift. (work in progress)
Olin18 is offline
post #3 of (permalink) Old 08-09-2001, 01:03 PM
Re: super 35 kit
I've got the super 35 in my 94 yj, and it holds up to mud, rocks, and anything else and I don't use a truss. I like it alot, But I am upgrading to 36" from a 33x 12.5 and I need more. oh, by the way I have the kit for sale with a lockright.
JR
Everyone has to believe in something, I believe I'll have more lift.
post #4 of (permalink) Old 08-09-2001, 01:45 PM
Re: super 35 kit
lilblkyj
How much are you asking for that kit? I may be interested Please let me know
Olin18 is offline
post #5 of (permalink) Old 08-09-2001, 02:27 PM
Re: super 35 kit
I alos may be interested in your super 35 kit lilblkyj if it will work in a 2001 TJ 35...If Olin doesn't take it, let me know how much.
Thanks,
http://bastroptx4x4.alloffroad.com
kerryp is offline
post #6 of (permalink) Old 08-09-2001, 02:54 PM
Pete88YJ's Avatar
Re: super 35 kit
For you guys who are looking into the Super35 kit $, and a truss $, and are regearing $, at least you leaf-spring guys, you may want to consider the Ford 8.8 axle.
Probably for about the same money, you can get disc brakes, and a lot stronger of an axle. The 8.8 came with 4.10s factory. I got my 8.8 with 4.10s.
Just a thought.
Good luck
Pete
http://ourworld.compuserve.com/homepages/jeep_macgyver
Pete88YJ is offline
post #7 of (permalink) Old 08-09-2001, 03:33 PM
dennisuello's Avatar
Re: super 35 kit
I've heard people say that 8.8 is a nearly bolt-on in YJ. What's all involved when installing one? How much grinding and welding is required?
thanks,
Denis
<>< 1992 YJ http://dennisuello.tripod.com/
dennisuello is offline
post #8 of (permalink) Old 08-10-2001, 06:23 AM
Pete88YJ's Avatar
Re: super 35 kit
There is a lot of info here on the 8.8 swap. Do a search if you're interested, and you will find a lot of info.
The basics are:
width is fine for a YJ, it's about 1/2" shorter than a D35 I think -- don't have to cut it.
bolt pattern same as a YJ -- stock wheels fit right on.
disc brakes from the factory [img]/wwwthreads_images/icons/smile.gif[/img]
some came with 4.10s from the factory -- no swapping required, if you want 4.10s (which I do).
strength is on par with a 9" or a Dana 44 (simimlar to one in some respects, the other in other respects)
availability is good.
The axle will be releatively new (you want '95 and up), so it should be in good shape. Scout axles, etc, will be 20+ years old if you get one.
When I was searching for what would be best for me, I couldn't find a YJ/XJ metric ton Dana44 (rare), custom axles are $$$, scout axles need new bolt pattern changes to use the 5 on 4.5 wheels, etc., etc.
You will need to cut the perches off and get new ones welded on, and there is a little brake line modification that needs to be done -- nothing major. There are more web sites on how to do this by those that have.
MORE has a kit to fit this axle to a YJ. It's a few $$, but you can get all the stuff in one box, or try to get it cheaper elsewhere.
Good luck
Pete
Pete88YJ is offline
