Starter, Please Help - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-06-2001, 10:54 PM Thread Starter
I have a 1988 jeep wrangler with the starter/solenoid combo. I know an 86 cj used the same combo but would like to know if a cj 258 starter from like a 84 will bolt up to my wrangler. Then I can just rewire a few things. thanks a lot. Mike
Jeeps are Built not Bought
pbytrailz is offline
post #2 of (permalink) Old 08-06-2001, 11:16 PM
Re: Starter, Please Help
The 258s for those years are all identical with the exception of head bolt sizes. I would think it would bolt up.
Brad
ORC Land Use Editor
Land Use
VP RockGarden 4 Wheelers, Aztec, NM
post #3 of (permalink) Old 08-07-2001, 12:02 AM
the 88 wrangler in question has a dc starter not a ford starter like the cj the wiring is there to make a cj starter work but you will need a cj solonoid as well as a ford style starter
jeep the first 4 wheel drive the only 4 wheel drive
3jeepguy is offline
post #4 of (permalink) Old 08-07-2001, 12:25 AM Thread Starter
3jeep, I planned on pulling a ford style solenoid also, but right now the wrangler also has a starter relay in it which basically is the same idea as the solenoid. So I believe those wires should go right onto the ford style solenoid.
post #5 of (permalink) Old 08-07-2001, 09:32 AM
Just use a Summit or JCW Starter Solenoid Relocation kit, or get a FOMOCO/JEEP style starter solenoid and rewire it yourself... save a few bucks til you need an new starter.
post #6 of (permalink) Old 08-07-2001, 01:25 PM Thread Starter
alright im at the wiring part! on my old relay there are 3 green wires, where they go? one is disconnected. the other goes under to the transfer and one goes up the loom. On the solenoid I want to replace this with from a cj there is a blue and red wire in the front. the blue goes to the fusebox and the red goes to the coil +. Now that I want to put this in my wrangler I beleive the green wire that goes up the loom will pass as the blue (probally ignition) then I just cut the coil power now and run the red line from the solenoid to it. Does this seem like it will work?
post #7 of (permalink) Old 08-07-2001, 06:10 PM
Do you have an automatic transmission or clutch interlock switch? if so then you need a Ford-style starter for a vehicle with an auto tranny (the bottom post is the neutral safety switch, it only lets the solenoid engage when it is connected to a ground)
This diagram from Painless Wiring might help
http://concrete.warzone.org/pictures...painless12.jpg
Mark
83 CJ-7 and 76 CJ-7 with stuff
sloop is offline
