- Jeep-Short Wheelbase
- - Starter, Please Help
(https://forums.off-road.com/jeep-short-wheelbase/82040-starter-please-help.html)
I have a 1988 jeep wrangler with the starter/solenoid combo. I know an 86 cj used the same combo but would like to know if a cj 258 starter from like a 84 will bolt up to my wrangler. Then I can just rewire a few things. thanks a lot. Mike
Jeeps are Built not Bought |
Re: Starter, Please Help
The 258s for those years are all identical with the exception of head bolt sizes. I would think it would bolt up.
Brad ORC Land Use Editor Land Use VP RockGarden 4 Wheelers, Aztec, NM RockGarden 4 Wheelers |
the 88 wrangler in question has a dc starter not a ford starter like the cj the wiring is there to make a cj starter work but you will need a cj solonoid as well as a ford style starter
jeep the first 4 wheel drive the only 4 wheel drive http://bbs.off-road.com/wwwthreads_u...8288825673.jpg |
3jeep, I planned on pulling a ford style solenoid also, but right now the wrangler also has a starter relay in it which basically is the same idea as the solenoid. So I believe those wires should go right onto the ford style solenoid.
Just use a Summit or JCW Starter Solenoid Relocation kit, or get a FOMOCO/JEEP style starter solenoid and rewire it yourself... save a few bucks til you need an new starter.
http://bbs.off-road.com/wwwthreads_u...MOVINGTEST.gif |
alright im at the wiring part! on my old relay there are 3 green wires, where they go? one is disconnected. the other goes under to the transfer and one goes up the loom. On the solenoid I want to replace this with from a cj there is a blue and red wire in the front. the blue goes to the fusebox and the red goes to the coil +. Now that I want to put this in my wrangler I beleive the green wire that goes up the loom will pass as the blue (probally ignition) then I just cut the coil power now and run the red line from the solenoid to it. Does this seem like it will work?
Do you have an automatic transmission or clutch interlock switch? if so then you need a Ford-style starter for a vehicle with an auto tranny (the bottom post is the neutral safety switch, it only lets the solenoid engage when it is connected to a ground)
This diagram from Painless Wiring might help http://concrete.warzone.org/pictures...painless12.jpg Mark 83 CJ-7 and 76 CJ-7 with stuff |
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
