speedometer correction - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-06-2001, 12:56 PM
Does anyone know how to correct the speedometer and odometer on a 95 yj when the tire size has been changed.
post #2 of (permalink) Old 08-06-2001, 01:25 PM
Re: speedometer correction
Nope, but I would really like to know.
Seems mine was adjusted before tires were made smaller, or gears were changed.
Keep putting along at 40 in 60 zones.
Do you think insurance will cover the carb if it some how "teleports" behind the tires of a 350 with dualies?
Infernozx is offline
post #3 of (permalink) Old 08-06-2001, 02:34 PM
Raduckal's Avatar
I know this has been discussed before. Maybe do a search for "speedo". You need to change your speedometer gear. It's not too hard, and it's just a different # of teeth. You could play with the numbers on http://dirtroad.com/gear.htm to find out the percent change of your new tires. Mine hits about 10%, thus 50 = 55 mph.
I'm on here so much, I have carpal tunnel reader syndrone.
Raduckal is offline
post #4 of (permalink) Old 08-06-2001, 07:22 PM
Calculators:
http://www.ring-pinion.com/Tech Libr...edometers.html
once you know which one you need, you can buy a new gear at dealership.
Max
82 CJ, some stuff stock, some stuff not
Have you hugged your Jeep today?
http://www.alpine14rs.org
CJ money pit is offline
post #5 of (permalink) Old 08-06-2001, 10:25 PM
kutyafal's Avatar
These links have some good description with part number and lookup tables for the tooth count:
http://www.jeepsunlimited.com/zj/speedo/speedo.htm
http://www.webejeepin.com/jeep-transfercase.htm
'91 YJ w/stuff, http://members.home.net/t.molnar
kutyafal is offline
post #6 of (permalink) Old 08-06-2001, 11:47 PM
just take it out and leave it out dont need it any way
"If its got tits or tires youre gonna have problems".
I make Half doors, for pics click here http://communities.msn.com/Grimjeepe...halfdoors.msnw
mike34 is offline
post #7 of (permalink) Old 08-07-2001, 06:32 AM
[img]/wwwthreads_images/icons/smile.gif[/img] Now on the late model stuff where the speed is measured by a sensor there may be a re-programmable element somewhere, but on the old stuff, there is a little transmission that goes in between the tranny speedo output nipple and the cable. It is like a little in-line gearbox and you can get them at the speedo shops. I have one on my pickup because at one time it had different sized tires. Usually the gears available at dealerships are only correct for the tire sizes and gear ratios that the Jeeps came with from the factoreeeee.[img]/wwwthreads_images/icons/crazy.gif[/img][img]/wwwthreads_images/icons/wink.gif[/img]*** Here is something I bet you didn't know.......SOME TRUCKS have a little "transmission" in the back of the speedo; or hanging on the tail end of the last transmission; a little gearbox which is shifted by vacuum, air, or electricity because some trucks have a TWO-SPEED AXLE and when you shift the axle, the speedo has to compensate for the difference in driveline-turns-per-mile.[img]/wwwthreads_images/icons/crazy.gif[/img] So you could find a wrecked out truck and nab the changeover transmission off the back of the speedo. Who knows, it just may be the ratio that you need.[img]/wwwthreads_images/icons/tongue.gif[/img]
CJDave
A Jeep Skunkworks run by Moonguys[img]/wwwthreads_images/icons/wink.gif[/img][img]/wwwthreads_images/icons/tongue.gif[/img][img]/wwwthreads_images/icons/laugh.gif[/img], buildin' the ultimate SNOJEEP!
CJDave is offline
