Cause of one HIGH compression cylinder? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-09-2001, 01:22 PM
Anyone know what might cause one cylinder to be significantly higher than the others? I was looking for a low cylinder, and this is what I found:
Cylinders 1,2,3,and 6 are all 170 PSI.
Cylinder 4 is 181 PSI, and #5 is 175 PSI.
Could this be the cause of any problems I'm having - such as lack of power, and rough running engine despite being perfectly timed? Or is this difference in PSI insignificant?
Thanks again...
Jed
80 CJ7 258w/TR,Holley carb,5" lift,33x12.5's.
post #2 of (permalink) Old 07-09-2001, 01:49 PM
Re: Cause of one HIGH compression cylinder?
That sounds high all the way across actually. How many miles on the motor. Excessive carbon buildup may be a possibility? Have you done a leakdown, that will give a better indication of the true condition of the motor.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 07-09-2001, 01:49 PM
Thats good compression, I'd try another gauge...Thats not enough difference to worry about.
post #4 of (permalink) Old 07-09-2001, 02:16 PM
I believe that the rule of thumb is as long as all cylinders are within 10% you should be o.k.
Shannon
78cj5 4.2
t176,dana300
post #5 of (permalink) Old 07-09-2001, 02:32 PM
Does it smoke (burn oil) excessive oil can raise compression! Good Luck:
Rodney C
1985 CJ7,302 V8,T18,D20,D44's,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's,Pony Carb...
CJ7JeepOffRoad is offline
