Engine from Tranny Removal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-09-2001, 10:48 AM
85Jeepny
I'm trying to remove a 360 from a TH400. Is there anything I could be missing that wouldn't allow it to seperate? All the bellhousing bolts are out, the starter is off and so is the dust shield. Do I have to remove flywheel and torque converter bolts?
post #2 of (permalink) Old 07-09-2001, 11:10 AM
Re: Engine from Tranny Removal
Remove the 4 maybe 5 bolts that hold the torque converter to the flexplate(flywheel)
Pigpen
76 CJ5 360/T18A/Bronco gear D20/D30 big brake disc, locker/D44 big drum working on disc/ factory slip/4inch lift/33's/6000lb winch/All Fiberglass/electric fan/full cage/ appetite for MUD
Pigpen is offline
post #3 of (permalink) Old 07-09-2001, 11:26 AM
As long as you are sure that ALL "6" of the transmission bolts are removed along with the dust shield there should be no other obstructions as the converter will seperate and remove while still bolted to the flexplate. If this unit has been sitting a while it could just need some good ole' muscles. Hope this helps.
http://www.jeep-shop.com
post #4 of (permalink) Old 07-09-2001, 02:45 PM
85Jeepny
Well, most of the bellhousing bolts weren't even there!!!!
It pops loose about 3" but then it won't move at all. Just rock and beat it up to move it out I guess. Thanks.
post #5 of (permalink) Old 07-09-2001, 03:07 PM
If you pulled the converter bolts it will come off, I don't know about AMCs, but on others the dust shields hang-up if you don't.
post #6 of (permalink) Old 07-10-2001, 01:26 AM
Official Historian
WILL's Avatar
There should only be three torque converter bolts.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #7 of (permalink) Old 07-10-2001, 08:02 AM
elusive's Avatar
only 3??? it's been a long time since i had a th400 in my jeep, but i know that my tf727 has 4 bolts in the converter..
~~Elusive~~
http://www.jeepgod.net
elusive is offline
post #8 of (permalink) Old 07-10-2001, 09:17 AM
85Jeepny
Thanks, I check the converter bolts.
