how to tell 4 bolt in 350 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-08-2001, 09:52 PM
How can I tell if a small block chev has a 4 bolt. does that mean that the bearing caps have 4 bolts holding each down? Thanks
post #2 of (permalink) Old 07-08-2001, 09:59 PM
Mike86CJ7's Avatar
Re: how to tell 4 bolt in 350
Yep, the main bearings have four bolts as opposed to two. Certainly a nice thing to have, but not necessary. A properly prepped 2 bolt block will easily withstand 450 hp.
'86 'glass CJ7, 33x12.5 BFG AT's 258, T5, D44
Mike86CJ7 is offline
post #3 of (permalink) Old 07-08-2001, 09:59 PM
Yes it does, I don't think you can tell from the outside.
post #4 of (permalink) Old 07-08-2001, 10:48 PM
You can tell by the small embossed emblem on the upper portion of the block at the rear just below where the intake bolts to the block, it will look like the letter "M" somewhat similar to the "double hump" embossing for the cylinder heads. Also a 2 bolt block with splayed caps added is much stronger. The 4 bolt block has 5 main journals but only 3 of them are 4-bolt.
Check with us for more info http://www.jeep-shop.com
post #5 of (permalink) Old 07-08-2001, 10:53 PM
Also the 400 cu.in block has the same set up of the three inside caps being four bolt ant the outside caps being two bolt.So if it is important to you to have a 350 block make sure you check closely.
post #6 of (permalink) Old 07-09-2001, 12:26 AM
dave's Avatar
If the bellhousing bolt hole at the top center of block is threaded, then it's a 4 bolt main. I've yet to see this indicator wrong. There are couple casting #'s that can be either two or four bolt main. Every block casting # that had the top center bellhousing bolt hole threaded turned out to be a 4 bolt main.
dave
PS, only the 350 and 400 would have had 4 bolt main block.
dave is offline
post #7 of (permalink) Old 07-09-2001, 04:52 AM
You don't really need a 4 bolt block! I don't think 454 ever came with 4 bolt mains but it can still withstand allot of power! Good Luck!
Rodney C
1985 CJ7,302 V8,T18,D20,D44's,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's,Pony Carb...
CJ7JeepOffRoad is offline
post #8 of (permalink) Old 07-09-2001, 10:49 AM
The 400 block has one more set of freeze out plugs than the other small block chevies this might help you out a little to determine which you are looking at.
