-   -   Ooops! Need bigger tires ?!? (https://forums.off-road.com/jeep-short-wheelbase/77866-ooops-need-bigger-tires.html)
kutyafal 07-08-2001 03:32 PM
Er.. I thought I'd get a little lift but now I'm stuck in my own garage. [img]/wwwthreads_images/icons/crazy.gif[/img] Is this normal? Do I like need some 35s now? Those are 33s on there. Maybe I just get some 44 slicks for the rear and leave the front as it is. [img]/wwwthreads_images/icons/smile.gif[/img] Big 8.8 is in now, what do you think of this pinion angle? (20 degrees) Is this normal?
http://webphotos.com/member/7612/201647.jpg
http://webphotos.com/member/7612/201648.jpg
http://webphotos.com/member/7612/201652.jpg
http://bbs.off-road.com/wwwthreads_u...-Tibor02sm.jpg
'91 YJ,I-6,2.5" lift,33s,D30,D35c,Lock-Rights F&R, SOA and Ford 8.8 soon http://members.home.net/t.molnar
sas87yj 07-08-2001 04:05 PM
Re: Ooops! Need bigger tires ?!?
well you want the pinion aimed at the transcase for the CV type set-up that you have right? i see you have SOA and the pinion does look steep but if it is aimed correctly then that's what you want. i still have the stock axle and spring under with 12 degree shims. you're not running shims right? you still have stock axle in front? going SOA there also right? looks like the SYE isn't leaking now! say what kind of rear bumper/spare swing-out do you have? that's what i am looking for now.
steve
87yj,6cly,5spd,NP231,4.5"RE susp,1" body,SYE,CV,32x11.50MTR's,D30,D35posi
kerryp 07-08-2001 04:10 PM
I think the important question is how are ya gonna get it outta the garage now [img]/wwwthreads_images/icons/wink.gif[/img]??? Looks good though, a little larger tire probably wouldn't hurt [img]/wwwthreads_images/icons/smile.gif[/img]
82 Scrambler/360/T5/D300/4" SUA/AMC20/Rear Discs/Somers Bros Axles/D30/3:73's/Lockrite Lockers.
2001 Bare Stock Trendy Jeep Sport (everyday driver)
Smithville, Texas
Member TX4X4 Cyber Club
kutyafal 07-08-2001 05:15 PM
Since it's a new rear axle I just rotated it to point at the tcase yoke, -2 deg. The driveline will be at 20 deg. I'm actually counting on a little spring sag. The rc D30 front will also go SOA soon. I'm a little worried about using a CV rear shaft with an offset pumpkin (compound angles). Sorry, the bumper/tire carrier is home made. Check my web page if interested. As for getting it out of the garge I hope if I get the tires down to 3 psi I'll loose a few inches. If not then I have to disconnect the rear shackles and let it sit on the springs while backing out. Ouchh!! [img]/wwwthreads_images/icons/shocked.gif[/img]
Bryan 07-08-2001 09:15 PM
1. Take the rollbar off and fold the windshield.
2. Use the hi-lift to raise the garage.
3. Just give it some gas and crash through the garage. (hey kool-aid)
wades_76_CJ7 07-08-2001 10:42 PM
just use a floor jack. take the wheels off and lower it down until it will go under.. If it is still too tall then i dunno.. just my $.02
76 CJ7, 258,Jeep T18, D20 TC, D30 & AMC20.
4" Superlift, 33" SSR's
JEEPN 07-08-2001 11:24 PM
Just drop the air pressure to about 2 pounds, back it out, and air it up.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 5" Calmini, Locked, Swamped, Rolled, and just generally broken in right!
**DONOTDELETE** 07-08-2001 11:38 PM
If the air pressure thing isn't enough, then get some of those rachet straps and compress your suspension. Get the axle on the frame and that should get you out.
Jason
<font color=green>----------------</font color=green>
<font color=green>[]llll[] '90 YJ</font color=green> & <font color=blue>'88 Grand Waggie</font color=blue>
**DONOTDELETE** 07-08-2001 11:39 PM
Now this idea might work <blockquote><font size=1>In reply to:</font><hr>
<hr></blockquote>
[img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img]
Jacob
Jeeplvr 07-08-2001 11:50 PM
Looks like a lot of hard work is paying off.
Did you narrow the 8.8 or are you going full size front and rear?
Are those lift springs or stock?
Jeeplvr
"Simple yet effective"
http:// www.trailhed.com
