-   -   CJ Axle Swap (https://forums.off-road.com/jeep-short-wheelbase/77849-cj-axle-swap.html)
KentuckyCrawler 07-08-2001 01:11 PM
CJ Axle Swap
I am looking to swap out the stock axles on my CJ and would like the best bang for my buck. I want to run 35' or 38" tires. Does anyone have any recommendations.
2001 TJ, 4.0L, 4" Tera Flex LA, Custom Drive Shafts, Front[D30(w/OX Locker], Rear[w/True Track], 33x12.50 GY MTRs on 589s. Comming rear OX Locker
'83 CJ7 Laredo,258-I6,Weber 38DGES Carb.
pontiac58 07-08-2001 03:50 PM
Re: CJ Axle Swap
You will hear all kinds of different response on this question. The first thing we all need to now is what kind of wheeling do you do. If it mud you can go with smaller rears but if you go for the rocks you need to go bigger. I pretty much only run mud and sand hills so i am building a 9in early bronco rear and a 44 waggy front cut down.
Can someone please bring me a hammer my 33's just ate my fender again. Damn i need more lift.
**DONOTDELETE** 07-08-2001 04:52 PM
Re: CJ Axle Swap
many different options. how wide do you want to be? what axles do you want to run? how do you plan to use your jeep? answer these q's and we can give you a better directed answer.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
vortec350/4L80E/d300/d60fr/14br/detroits/4.56/38's
**DONOTDELETE** 07-08-2001 08:16 PM
Re: CJ Axle Swap
Since you are from the south like I am, I'm going to tell you to find some Chevy 1-tons and be done with it! Get the lowest gears for them and some Detroit lockers and you'll be able to take on anything!
KentuckyCrawler 07-08-2001 08:53 PM
Re: CJ Axle Swap
I want to build it to wheel anywhere because with the job I have I can move anywhere from coast to coast. I am however on a budget; therefore, what would be the best way to go about getting my hands on some good axles. I have a TJ with a pretty good set-up, will just swap in a Dana 44 up front when I trash the Dana 30 and a pair of warn axles.
2001 TJ, 4.0L, 4" Tera Flex LA, Custom Drive Shafts, Front[D30(w/OX Locker], Rear[w/True Track], 33x12.50 GY MTRs on 589s. Coming rear OX Locker
pontiac58 07-09-2001 06:52 AM
Re: CJ Axle Swap
Take a look at jeepgods website and look at what he used. His front rear is no problem to find. His rear is a tuffer one to find but is one heck of a set up. This may be what you are looking for. Its not over built but not under built.
**DONOTDELETE** 07-09-2001 09:20 AM
Re: CJ Axle Swap
I've got a D-60 rear 5 lug and several D-44 fronts that drop on either side. Email if interested.
http://www.jeep-shop.com
