-   -   Did I break something? (https://forums.off-road.com/jeep-short-wheelbase/77846-did-i-break-something.html)
**DONOTDELETE** 07-08-2001 12:55 PM
I was helping my neighbor "de-landscape" his yard this morning by ripping out some trees with the ZJ. I had it in 4lo, on the driveway (I know I know). I kept any maneuvering as straight as possible. Nonetheless, there was a lot of banging and popping going on.
After I got the trees out, I put 'er in 2wd and drove around a while (it doesn't ever disengage the axles right away). Should I check the axle u-joints? The diffs are open, so I don't think its anything there. Or are these typical 4wd noises? The only other info I can offer is the front two tires are more worn that the rear by about 3/16". Is that putting undo stress on the t-case and making the chain slip?
Who needs a road...if there's a perfectly good JEEP trail somewhere else!?
**DONOTDELETE** 07-08-2001 06:13 PM
Re: Did I break something?
The extremely short distance you had to operate in 4 low shouldn't have had any effect on the t-case, look for another source of the noise.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
**DONOTDELETE** 07-08-2001 06:30 PM
It is quite possible that, if you were on a hard surface in 4wd...you were just hearing normal suspension and tire banging...I wouldn't worry too much unless you hear it when operating in 4wd under less stressful situations
Moneyless, Will weld for jeep accessories.
