Re: ignition switch
It a little more than just pulling the steering wheel, which is not always easy, I've bent them try to get them off without a puller. Then you'll have to remove the lock plate, a special pusher(CJ's use Chev type) is handy or a strong buddy and a couple small screwdrivers or lock ring pliers. Then remove the signal switch to find the cyl lock screw. Some models also have a pin to depress. If the cylinder isn't function at all your going to have a much harder time. Anyway when youremove the locking screw you have to turn the key one way or the other and pull the whole assy out. Watch the rack and pinion for the switch it's a bitch to set up correctly after.
Glenn
Build what I can, buy only what I must.[img]/wwwthreads_images/icons/crazy.gif[/img]
82CJ7 Rebuilding again.
