Help Please Jeep running bad - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-06-2001, 11:09 PM Thread Starter
My 88YJ has me stumped, it starts up great and running good until it warms up, then the motor will almost stop at a light and it brakes up as it runs down the road. I have put on a new set of plugs, wires, distributor cap, rotor. The Jeep has 132,ooo miles on it but do not use any oil and has good power. It has had a Weber carb for about one & half years now and TR's ignition up grade for about one year. For three or four weeks now the problem has been getting worse. Any one have any Ideas. Could it be a bad catalyic converter?
My Jeep is a work in progress, Happy Trails
Woodsrider is offline
post #2 of (permalink) Old 07-06-2001, 11:25 PM Thread Starter
Re: Help Please Jeep running bad
Anyone have any ideas? I sure need the Jeep this weekend.
Thanks!
post #3 of (permalink) Old 07-06-2001, 11:29 PM
I'll bet on a vacuum leak...
post #4 of (permalink) Old 07-06-2001, 11:34 PM Thread Starter
Thanks LEVE I have check for a vacuum leak, but I will give it a good check over again. Thanks
post #5 of (permalink) Old 07-06-2001, 11:34 PM
Well, it's hard to tell, could be lots of things, is the choke opening all the way ? are the sparkplugs black and sooty (running rich) or white (lean)... does the tailpipe smell bad ? It could be a coil or "mystery box" failing, maybe some goofy emmision control device screwing with the timing. Could be a dirty carb or a sticking float or needle and seat.
post #6 of (permalink) Old 07-07-2001, 07:03 AM
the easiest way to check for a vacuum leak is to partially choke the engine when it is running rough if it gets better it is a vacuum problem if it gets worse than start checking things like the cat and so on
jeep the first 4 wheel drive the only 4 wheel drive
3jeepguy is offline
post #7 of (permalink) Old 07-07-2001, 09:56 AM
my wifes cougar with the 5.0 had the same symptoms. start good and run great for about 15 minutes and then stall, hesitate, run rough.. etc. It was a bad cat on her car. easy way to tell is hold your hand close to the exhaust pipe and feel the pressure when you first start it. then run it until it starts to run bad, and then check it again. if it is noticably less, you're plugged.
J ust
E mpty
E very
P ocket
yjdave is offline
post #8 of (permalink) Old 07-07-2001, 10:51 AM
Whats the outcome?
<font color=red>[img]/wwwthreads_images/icons/cool.gif[/img] 78 CJ7 "Issues" [img]/wwwthreads_images/icons/cool.gif[/img]</font color=red>
post #9 of (permalink) Old 07-07-2001, 02:30 PM Thread Starter
I had a engine dianogistic test ran this morning and two of the new Bosch plug wires were bad, Put on a new set of Borg Warrner wires and it is running great again, thanks.
