TR upgrade question... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-06-2001, 04:00 PM Thread Starter
OK, What's the real scoop? Do I or do I not need the resistor on the firewall that I used with my old ignition? The instructions said to use it, but I read recently to eliminate it. Which way works better?
Thanks.
'86 CJ-7, 360, TFI, 727, OEM Dana 44 rear w/Truetrac, Dana 30 w/Powertrax No-Slip, 4" Superlift, 4:11s, Warn HS9500i
BillR is offline
post #2 of (permalink) Old 07-06-2001, 05:18 PM
jeepgod's Avatar
Re: TR upgrade question...
mmm.. the instructions i have.. say.. NO resistor.. that the tfi coil takes all 12 volts..
any ford guru's here.. i am about to put it on mine this weekend.. if the junkyards around here ever open up.. jeesh.. youd think it was a holiday or somethin...
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 07-06-2001, 05:34 PM
Bill, and Jeepgod... your questions and answers are good...however there seem to be mixed results in coil longevity using the full 12 volts to the coil. A TFI coil is engineered to be used with the FOMOCO TFI ignition system. The OEM Jeep FOMOCO system uses a different ignition module and distributor. This raises questions about pulse time, width and TFI coil saturation using the OEM Jeep FOMOCO ignition module. I believe this is where the variance occurs. If the module produces a wider, longer lasting pulse the coil become saturated for a longer time. There is little time for the coil to cool before the next pulse. This leads to premature failure. Another ignition module (AutoZone, Pepboys, etc.) may produce a shorter pulse and the timing works out OK. This does not burn up the coil. Like my kids are fond of saying: "It's the same thing, only different." I don't have the insturmentation or the desire to do follow up on this question so I'll just stick to my GM HEI ignition.
post #4 of (permalink) Old 07-06-2001, 06:17 PM
Mine has been running for about a year now and has the resistor in it. The voltage at the coil is about 4.6 volts
lindy80cj7 is offline
post #5 of (permalink) Old 07-06-2001, 08:07 PM
jeepgod's Avatar
ok.. so you are running.. 4.6 volts.. mmmm.. Elusive is running the full 12 volts in his.. and they are not lasting.. but a month maybe..
and i understand what you are getting at leve.. mmmmm... ill will some drinkin tonight.. and some thinkin.. and maybe some research this weekend... if im not that hungover.. [img]/wwwthreads_images/icons/laugh.gif[/img]..
ill see what i can dig up.. and expeirment with..
jeepgod is offline
post #6 of (permalink) Old 07-06-2001, 08:20 PM
lindy80cj7, 4.7 DC volts does seem very a low coil voltage. I'd be happier with it being between 8.2 and 8.9 DC volts. If you're using a resistor, try replacing it with one of a smaller ohm value. The smaller the ohm value will result in a larger voltage to the coil.
If the resistor is in the form of resistor wire then cut out about 1/3 of it's length. That should bring up the voltage to about the correct voltage.
It is true that with the higher voltage to the coil, a higher spark output will result from the coil.
Jeepgod, let me know what you come up with. If Elusive's using the full 12 volts and the coil is not surviving, then the problem is clear.... full voltage is killing the coil. Resistance should be placed in series with the coil to cut down the voltage to the coil.
post #7 of (permalink) Old 07-06-2001, 11:36 PM
jeepgod,
Your instructions may say no resistor because the stock positive coil wire is already a resistor wire. If it has been replaced, then yes a ballast resistor is necessary. Elusive will have better luck with coils if he would step it down to about 8.5 to 8.9 volts.
'75 CJ5,258 w/Howell EFI,T18a,4.27's,33's,On-board air,Warn 8274
post #8 of (permalink) Old 07-07-2001, 08:01 AM
jeepgod's Avatar
ok.. ya.. i took out that resistor wire long ago.. when i went back to running points on an old I6... so now i just have the ballast resistor in....
jeepgod is offline
post #9 of (permalink) Old 07-07-2001, 12:57 PM Thread Starter
I took the ballast resistor out of the circut, and didn't notice any difference in starting or acceleration. I just re-installed it back into the system to help the coil last longer.
BTW, I'm getting about 5.2 volts at the coil at key-on and around 10.5 volts while running. Does this sound about right?
BillR is offline
post #10 of (permalink) Old 07-07-2001, 11:43 PM
Bill, it seems something is not quite right.
Ususally in the START mode full 12 volts are applied to the coil. This gives the hotter spark and aids in starting a cold vehicle.
When in RUN mode the voltage is lowered to between 8 and 9 volts to pereserve the coil.
