-   -   Oil pressure sending unit????? (https://forums.off-road.com/jeep-short-wheelbase/77563-oil-pressure-sending-unit.html)
**DONOTDELETE** 07-06-2001 09:28 PM
Re: Oil pressure sending unit?????
I'm not sure about the sending unit deal, some units are a open circuit until you lose pressure then it grounds and completes the circuit, I'm sure there are several ideas out there but I'd think a brakelight pressure switch should work fine, they have a pipe thread on them and would close the circuit when you have pressure, you would probably want to use a relay for the pump feed, and use the pressure switch to feed the relay.
LEVE 07-06-2001 10:10 PM
Would it be easier to install a mechanical anti-roll over valve in the input to the fuel pump?
http://bbs.off-road.com/wwwthreads_u...5-LEVELOGO.jpg
**DONOTDELETE** 07-06-2001 10:14 PM
Or, just turn off the damn key...Thats what I do
jeepgod 07-06-2001 10:17 PM
whoa.. doggies...
if and when i roll over.. ill just turn it off.. i dont it several times already.. but.. that is alittle advanced for me now.. i wish i could set it up like that.. but i dont have the time... not until i return next month.. from leave.. i will keep it in mind..
http://www.jeepgod.net
Frank360 07-09-2001 07:31 AM
Well I hooked up the pump to the acc where I ripped the old sound system... I grounded the pump on the bracket that holds the pump to the tub... To my big amazement, it worked... What should I do with the old mechanical pump, well, it still works, it's just pumping air from nowhere to nowhere ?? Do I just leave it there with the old pieces of fuel line ?
'89 YJ, AMC360, T-15A, D20, D44 F&R, 33' BF MT, mud, rust and some body paint left
jeepgod 07-09-2001 09:01 AM
[img]/wwwthreads_images/icons/laugh.gif[/img].. like i said.. i did mine on the side of the highway.. so my mech is still there.. pumping air to air.. someday i will get around to pulling it off.. and using it for a template.. and then make my own block off plate for it.. so far its been two weeks there.. nothing abnormal as of yet.. cross your fingers..
