Extended my Wheel Base to 99"(wagoneer springs) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-06-2001, 02:25 AM Thread Starter
Extended my Wheel Base to 99\"(wagoneer springs)
I screwed up my driver side rear, main leaf spring, pretty baddly, durring some heavy footed, rock climbs at bald Mountain a couple of weeks ago. Actualy they were already, showing signs of heavy use/abuse after Moab.
So a couple of days ago I installed a set of of 6 leaf Rancho 2 1/2" lift, Wagoneer springs. I did no modifications to the rear shackle positions, but did use a set of my own 5/16 inch shackles with no cross support, to allow the springs to twist a bit easier. The waggy boingers moved my axle back another 2 1/2" to a total WB of just a hair over 98 1/2". The pig still clears the gas tank , but just barely(Ill know how much room I really have, after this weekend. I had to have my rear drive shaft lengthened,( I ramped it at a wharehouse loading dock, and only had about an inch of spline left when the front tire was 51" above level). I also had to make modifications to my anti wrap bar. Everything appears to work great though. Im gonna put it through its paces this weekend on the Rubicon. Ill o get some pics and, give the low down on performance when I get back.
99" of wheelbase, whats not to like about that though.
Later.
Jeff
89 YJ
Wow, you can get a nice tan on your arms, from welding with no shirt on.
H8monday is offline
post #2 of (permalink) Old 07-06-2001, 10:48 AM
elusive's Avatar
Re: Extended my Wheel Base to 99\"(wagoneer springs)
jeff.. wait till you swap in a d-60 or 14 bolt and you dont just barely clear anymore...but my 22 gallon tank has a nice "clearance dent" in it now and doesnt rub. i am at 98 1/2" also, but i had to trim the rear or the tub cause the tires were not centered in the wheelwells anymore.
another thought i have allways wanted to try was ford springs.. some of the ford truk springs have center pins that are off centered by like 5"..useing spings that are as long as they are would give the best of everything, but that another mod for down the road.. i have the springs though...
~~Elusive~~
http://www.jeepgod.net
elusive is offline
post #3 of (permalink) Old 07-06-2001, 03:42 PM
You know, I see new posts from Jeff with a mixture of emotions. The first is excitement, since he's out there doing all the stuff I can only wish for. Close on the heels of that is the "AW CRAP!!! That's just too cool where am I going to get the time to get that done?!?!"
Keep on wheelin'!
bluseman2a is offline
post #4 of (permalink) Old 07-06-2001, 11:16 PM
i hope you have better luck with them than i did. i bent a leaf and broke another after only a few trips when i tried a set of cherokee springs. they were cherokee and not wagoneer and they had only 3 thick leaves compared to the 4 or 5 thinner leaves i have seen on the wags. i have heard of people having good luck with wag springs though so you probably won't have a problem.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
vortec350/4L80E/d300/d60fr/14br/detroits/4.56/38's
