Fix for bent leaf springs? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2001, 09:50 PM
I recently added Con-ferr heavy duty shackles with a 3/8 inch lift on my Cj-7. The stock shackles on the rear were torqued out towards the tires. Since adding the new shackles this has lessend but there is still a bit of bend outwards. Would I have to remove and remount the leaf springs to correct the outward angle? Any insight would be helpful, thanks.
post #2 of (permalink) Old 07-05-2001, 10:15 PM
Re: Fix for bent leaf springs?
Did you replace the spring bushings ? If not, that should fix it.
post #3 of (permalink) Old 07-05-2001, 10:42 PM
I purchased front and rear poly bushings and installed the new shackle bushings but held off on the spring bushings. I'll put them on this weekend and see if that takes care of it.
post #4 of (permalink) Old 07-05-2001, 10:57 PM
Did you put a different axle in? If so than maybe the spring perches are to far apart! Good Luck.
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's Mud's,Pony Carb...
CJ7JeepOffRoad is offline
post #5 of (permalink) Old 07-05-2001, 11:48 PM
No, it has been all stock suspension and axles till now.
post #6 of (permalink) Old 07-06-2001, 08:12 AM
RickB's Avatar
I have heard that all you have to do is loosen the u-bolts and straighten the leaf springs and retighten the u-bolts. I have never tried this so I can't say how well it works.
Rick
80 CJ7
258 T176 TR upgrade
RickB is offline
