Is spring center bolt generic replacement? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2001, 01:35 PM Thread Starter
kutyafal's Avatar
I'm swapping out the rear and after removing the u-bolts and the plate the pass. side spring pack fell apart indicating I guess that the center bolt is broken. How are these things supposed to be? Is this bolt supposed to hold the pack together? Is it a generic bolt that I can replace easily?
'91 YJ,I-6,2.5" lift,33s,D30,D35c,Lock-Rights F&R, SOA and Ford 8.8 soon http://members.home.net/t.molnar
kutyafal is offline
post #2 of (permalink) Old 07-05-2001, 01:41 PM
Re: Is spring center bolt generic replacement?
I think you can use a grade 8 hex head cap screw from your local hardware store.
-Jay
Denver, CO
1978 CJ-5 258 Weber, 'glass body
post #3 of (permalink) Old 07-05-2001, 02:43 PM
jeepfiend
Center bolts are generic. You just need the correct diameter. The bolts are always long, and you tighten them in place, and cut off the excess length. I have gone as far as grinding the flats on a standard bolt. Fine threads work a little better, because it is easier to tighten the spring pack together.
Cage Up, Wheels Down
Jeepfiend
All my Jeeps are in pieces!
post #4 of (permalink) Old 07-05-2001, 04:31 PM
If you have a 4x4 store near you just go buy two, they're cheap. They are
like an allen head capscrew with out the place for the allen wrench. They
should be 3/8"
Gary
