York Head transplant successful...an oil question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-04-2001, 07:53 PM Thread Starter
Well, so far so good. I swapped the heads from two different Yorks and the new one works well. So I am now consumed with the desire to prevent a relapse of my previous error and went to check the oil. I noticed that it was low, and that it was RED! What kind of oil would this be?
Fritz
Jeep...need I say more?
ExtinctJeep is offline
post #2 of (permalink) Old 07-04-2001, 08:56 PM
Re: York Head transplant successful...an oil question
Sounds like hydraulic fluid or tranny fluid to me...I just use 30W in mine...I also did a head change with success..
78 CJ5 w/360
"measure it with a micrometer, mark it with chalk, and cut it with an axe"
jeepsternaut is offline
post #3 of (permalink) Old 07-04-2001, 09:02 PM Thread Starter
Okay, so I found this in the York manual. Which one of these would be red?
Fritz
post #4 of (permalink) Old 07-04-2001, 09:04 PM
maybe the PAG oil is red, who knows, it deosnt matter, the darn things will usually run for hundreds of hours on a few oz of whatever you have handy
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
post #5 of (permalink) Old 07-04-2001, 09:07 PM Thread Starter
Do I have to drain the little amount of red stuff before putting in another kind of oil?
Fritz
post #6 of (permalink) Old 07-04-2001, 09:33 PM
well if youve already got it apart and draining is easy, I would, but really does it smell like normal oil? or something else?
if its eaqsy drain it and refill with Non detergent 30wt ( autozone 99cents per quart)
Im still not understanding what youve done? you swapped the head from the locked up YORK onto another one? or what?
OzarkJeep
post #7 of (permalink) Old 07-04-2001, 10:32 PM Thread Starter
Ozark,
Yeah, I had a York seize due (I suppose) to lack of lubrication. When I went to find a new (no mean feat in Nashville), I found a Mercedes 210R York that worked, so I bought it REAL cheap. When I got it mounted up, I found that the intake and exhaust were different from the ones I had (the ones on the new York were mangled), so I figured I would just replace them. Well, the threads were the same, but not the sealing system. SO I just swapped the entire top end from my old one to the new one.
Now its bolted in and hard as h#ll to get out again, so I would prefer using the style of oil in it if possible.
Fritz
post #8 of (permalink) Old 07-05-2001, 10:33 AM
Journeyman
gmoabrim's Avatar
Back in my R-12 wrenching days there was a product available you could add to the freon system to help locate leaks, it contained a red colored oil. Perhaps this is what you have.
GM
gmoabrim is offline
post #9 of (permalink) Old 07-05-2001, 09:46 PM Thread Starter
btt
post #10 of (permalink) Old 07-06-2001, 12:15 AM
TOM85CJ7's Avatar
Go to a jiffy lube or some other oil change place and have them suction out all of the existing oil. The have a suction device they use to drain tcases and trannys, Just tell the there is some oil you need sucked out. Then put in new 30wt non-detergent oil like Ozark said. Or just add to the red stuff. I am sure it won't hurt it since it is what was in there to begin with. Don't overfill it or you will be blowing oil through your air system for quite a while. On-boardair.com has the complete York manual on-line if you didn't know.
Later,
http://home.off-road.com/~tom85cj7/home.htm
TOM85CJ7 is offline
