Determining the overbore on a rebuilt - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-04-2001, 06:17 PM Thread Starter
How do I determine how much (if any) an engine was overbored during a rebuild by someone else? The engines a rebuilt and needs a set of rings in one cylinder. Could I take the piston to a machine shop and have them put the micrometers on the piston? Or is stamped somewhere, like inside the piston skirt?
Thanks,
Brett
done is offline
post #2 of (permalink) Old 07-04-2001, 06:25 PM
Re: Determining the overbore on a rebuilt
it's stamped on top
post #3 of (permalink) Old 07-04-2001, 06:26 PM
In most cases it's stamped or cast onto the top of each piston along with the arrow pointing to the front. You certainly could measure the piston as well. Typical overbore is plus 0.030.
tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, Lockright, full cage & belts, Xenon flares, AMC 20 1pc axles, GM dual diaphragm brake booster
TiminMb is offline
post #4 of (permalink) Old 07-04-2001, 07:12 PM
You could get a micrometer and measure the cyclinder?
<font color=red>[img]/wwwthreads_images/icons/cool.gif[/img] 78 CJ7 "Issues" [img]/wwwthreads_images/icons/cool.gif[/img]</font color=red>
post #5 of (permalink) Old 07-04-2001, 08:08 PM
if the pistons arent stamped 0.030 or 0.060 then its probably standard bore
you can also remove a crank bearing cap and the back of the shell will be stamped with any oversize information.
be aware though, some amc engines from teh factory had turned cranks 0.010, or even oversized bores, these are discernable from teh engine build id tag on teh valve cover if still there
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
