parts at the local pick and pull - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-03-2001, 06:53 AM Thread Starter
went to my local pick and pull today and found several jeeps my question is i can get a v8 motor 4 speed tranny and tcase out of a 1978 or so fs cheerokee with the passenger side drop was wondering what the tranny and tcase were (maybe t18 and dana 20 ) and if they would work in my cj7
jeep the first 4 wheel drive the only 4 wheel drive
3jeepguy is offline
post #2 of (permalink) Old 07-03-2001, 07:32 AM
Mel85CJ's Avatar
Re: parts at the local pick and pull
check out www.ifsja.org
(That stands for international full size jeep association)
I believe it may be the T18, I'd check that site for sure
-Mel
http://www.in2jeeps.com
Mel85CJ is offline
post #3 of (permalink) Old 07-03-2001, 07:45 AM
Remember that the T18s used in the FS had a longer input shaft and adaptor. It pushes the tranny back an additional 6-8 inches. You can swap in the shorter CJ input shaft
Pigpen
76 CJ5 360/T18A/Bronco gear D20/D30 big brake disc, locker/D44 big drum working on disc/ factory slip/4inch lift/33's/6000lb winch/All Fiberglass/electric fan/full cage/ appetite for MUD
Pigpen is offline
post #4 of (permalink) Old 07-03-2001, 02:14 PM Thread Starter
back to the top
3jeepguy is offline
post #5 of (permalink) Old 07-03-2001, 03:53 PM
if its a 4 speed, and no one swapped it around, its a T18, if its a 3 speed its a T150, the tranfser will be a dana 20
the input shaft behind V8 FSJ was about 15 inches long, with a spacer between bellhousing and tranny.
if you have a short wheelbase ( CJ5) you ll need a T150 bellhopusing ( easy to find) and a Ford T18 input shaft ( pretty easy to find also)
then you have a short T18, with Dana 20
its what Im in the process of doing, I got the tranny for $100 from a J10, the input shaft from a guy in the PIrate BBS for $43, and Ill install new bearings in the tranny while its apart ( $100 kit)
cheap T18
one thing though, it MAY NOT have the granny first gear, youll have to turn the input shaft and count rotations to see.
there is no way im aware of to tell if its granny or not visually.
good luck!
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
post #6 of (permalink) Old 07-04-2001, 10:54 AM Thread Starter
i was thinking of putting this in my cj7 would that be a problem still with the length or could i get away with it in my cj7
3jeepguy is offline
post #7 of (permalink) Old 07-04-2001, 11:48 AM
JeepGod runs a full length one in his CJ7, if you have a V8 its probably alright ( although the rear driveshaft could be shorter)
if you have an inline 6 then it probably wont work.
OzarkJeep
