how to pass emishions?? help please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-03-2001, 03:07 AM
i have a 1980 cj7 with a 304 v8. and it burns a little oil. you cant see it from the tail pipe while its running. it only gives a puff of smoke when i first start it up but then it clears up. so i changed my oil i put 30 weight oil in it and tryed stps engine smoke stoper addetive. is there anything i can add to the gas to get better emishions? anything at all. you cant see any smoke at all while its running just when it starts i want to make sure i pass the first time.
thanks
80 cj7 304, WC t-5
post #2 of (permalink) Old 07-03-2001, 05:16 AM
sas87yj
Re: how to pass emishions?? help please
i don't think you need to worry much about the oil use for smog test. hydrocarbon and carbon monoxide are the criminals they test for i believe. also the visual inspection for altered smog devices. just make sure the timing is close and good plugs. i always set the idle up a hair.
steve
87yj,6cly,5spd,NP231,4.5"RE susp,1" body,SYE,CV,32x11.50MTR's,D30,D35posi
post #3 of (permalink) Old 07-03-2001, 07:17 AM
Mike86CJ7's Avatar
Also make sure you get the engine good and hot before putting it on the sniffer. I used to do this with an Oldsmobile I used to own. If I drove it around for an hour or so before the test, it passed just fine. At the very least, make sure the engine is up to normal operating temperature. If your exhuast looks clear after that, you should be OK.
'86 'glass CJ7, 33x12.5 BFG AT's 258, T5, D44
Mike86CJ7 is offline
post #4 of (permalink) Old 07-03-2001, 01:45 PM
thanks alot guys. i wasn't sure what kind of stuff they tested for. i'll get it nice and hot. what about octain boost or any of those other gas aditives?
80 cj7 304, WC t-5
