I just put a new exhaust manifold on my 79 CJ7. Where the old manifold was flat and a flange gasket was used at the pipe connection, the new one has a beveled extension that is shaped like a flange gasket. My question is, is this some sort of compression fitting or is there a special gasket that goes on this setup? Thanks.
The headpipe should be formed to seal against this type flange without any gasket what-so-ever. The new manifold flange eliminates the need for a gasket which always leaks on the earlier type. If your headpipe is perfectly flat where it joins to the manifold, you should go to the muffler shop and have a new header pipe made to fit. If you already have the flared pipe, it should fine.
Hope this helps, good luck!
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
