I have a '97 TJ, and need to do a tune up on the straight six. The A/C compressor is right on top of the #1 spark plug. Any one done this before? Do I just loosen the four bolts on top of the Compressor (after removing the belt) or is there another trick?
The swivel socket is definitely a big help. The hardest part for me is getting the blasted wire back on to the new plug. If you take the bolts out of the a/c mount make sure to put some anti seize on them. Steel bolts into aluminum hole=stuck after a few years.
A set of insulated plug wire pliers is a big help on removing or reinserting that front plug wire without damage. Use dielectric grease inside the boots to ease assembly, and later removal, along with improved water protection.
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
