Have an 85 CJ7 with four speed trans. Want to replace shift lever with OEM lever. Jeep is currently being rebuilt and I can't get to it to see which 4sp. trans it has, but reverse is Up and Left. Can anyone tell me which trans this is and where I can get OEM lever and knob?
well lets see....1985 there were two 4 speeds....the T-176 and the t-4....i think the T-4's reverse was down to the right....so a good guess is the T-176....if you can take a look at the trans it would help...the T-176 had a smoother casing than the T-4 which had a set of 4 "ribs" running length wise and one "rib" running vertically crossing the other 4.....
ok i guess that doent help much if you cant see it
once you figure out which one it is, you can get OEM shifters from 4WD Hardware catalog or call (800)333-5535 theres several parts you'd need to order so i recomment gettinhg thier catalog
you be an unlucky folk like me and have an sr-4 ..
reverse is left and up
81 cj 7
98 tj
81 cj7
jeepersjeepclub.com
thejeepclub.com
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
