Obnoxious engine hesitation. Missing something??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-01-2001, 07:09 AM Thread Starter
Well the jeep ran fine four weeks ago. I couldn't drive it though, because i had to replace power steering pump. I replaced the pump and at the same time replaced my brand new 650 holley 4 bbl with 390 Holley 4bbl. The 390 was a used unit. I put it on and started the jeep up. Gas started leaking from carb. I tightened bolts.Gas stopped. Jeep ran fine. I parked her. Two days later. i started her up. After about minute the jeep starts stumbling and belching black smoke. I notice the carb it is leaking in the back left corner. I decide to pull it to rebuild and throw back on the Holley 650, which has about 200 miles on it. I start the engine after i get carb on. It purrs just fine. I give her gas and it stumbles and almost dies. If i give it two or three quick pushes on the throttle it will stay running. Here is what I have did so far:
Cleaned plugs
Checked timing
Replaced cap and rotor
Replaced coil
This is a 4.1L buick V6 with HEI. The engine runs fine when i give it gas and keep it up. Am I overlooking something? It seems to be a vaccuum leak, but i am not sure. I am kind of stumped on this one. I will see if the carb needs to be tightened down anymore. All of my vacuum ports have the correct hosses on it, or is plugged off. There might be trash in the carb, but the cabr only has 200 miles on it.
Any suggestions of what i may be overlooking??
Thanks very much
Dan Stewart 1963 CJ5 "Caloosa Jeepers" member
DanStew is offline
post #2 of (permalink) Old 07-02-2001, 08:21 AM
webjeep's Avatar
Re: Obnoxious engine hesitation. Missing something???
not sure what youre running. maybe im just still asleep and not paying attention, but anyway, i had a 78 cj5 with very modified 258, including the clifford intake and initially a holly 4bbi, later switched to edelbrock (less flood problems rock crawling) but anyway i had what sounds like the same problem and again if it doesnt apply ignore me, but my ignition module crapped the bed and the one i replaced it with was broke too so i did alot of work for a simple problem, well anyway if it applies cool, if not oh hell sorry for wasting your time, good luck :-)
webjeep is offline
