I bought some Daystar shackles for my CJ. The shackles have a reinforcing tube that is welded in between the two side plates. On the front shackles the tube is welded directly in the center. On the rear shackles the tube is not centered. Does the shorter end mount to the spring perch on the frame or is it the other way around? Thanks!
Just a suggestion, hang the shackle from the frame and swing it all the way up like the spring is compressed. I'll bet you
need the more room on the up side to allow for full compression.
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
