>>>>>>>>please explain axlewrap<<<<<<<<<<<<<<<<< - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-27-2001, 03:26 PM
please explain axlewrap in simple to understand instructions also pertaining to a SOA conversion
thanks
[email protected],
schaan
1980 CJ7 75% completed
1969 Early Bronco 40% completed
post #2 of (permalink) Old 06-27-2001, 03:34 PM
I Do This For The Glory
JEEPN's Avatar
Re: >>>>>>>>please explain axlewrap<<<<<<<<<<<<<<<<<
Please do a search on this, there was a GREAT explanation posted not too long ago.
Basically it's the rear axle twisting upwards due to the torque applied from the motor. The soft springs wrap into an "S" shape and damage the springs and U-joints.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 5" Calmini, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 06-27-2001, 04:11 PM
Pooh-Bah
pbmcauliffe's Avatar
This does a great job of explaining the ways to cure it.
http://www.outdoorwire.com/4x4/jeep/tech/susp/axlewrap/
<font color=blue>pbm</font color=blue>
74 CJ5,304,t18,2.46 ts d20,30f,44r,locked f&r,SOA,MORE SRS buggy front,35's,Rci's,5pt,full cage,air,etc.
<font color=red>Support Search and Rescue.......Get Lost!</font color=red> [img]/wwwthreads_images/icons/shocked.gif[/img]
pbmcauliffe is offline
post #4 of (permalink) Old 06-27-2001, 07:32 PM
here's how i think about it,
1. when the torque of your engine drives the rear driveshaft(pinion gear) to rotate the (ring gear)axle shafts and tires, there is an opposite reaction, (this is the one that pushes the front wheels in the air when a dragster takes off [img]/wwwthreads_images/icons/smile.gif[/img])
so when the tires are rotated one way, the axle housing wants to rotate the other way.
2. the arch of leaf springs gets flatter as more weight is loaded on, and when the axle housing tries to rotate the spring are forced to take a kind of laying down "S" shape. this is "Spring Wrap"
the problems that happen with too much spring wrap or many, the biggest is "Wheel Hop" this occures when your springs wind up (like and "S") and release again and again, this caused your rearend to bounce. (which can cause all kinds of different breakage)[img]/wwwthreads_images/icons/smile.gif[/img]
so, this affects all leaf spring axles.
very stiff springs can control this (but are not very flexible)
low engine torque and axles with highway gears (2.73/3.07etc..) don't have the mechanical leverage to cause many problems. (not a great wheeling setup)
softer/flexible leaf springs can be wound-up easier along with super low gears possibly creating an overpowering mechanical advantage.
also spacing the axle housing farther away from the springs (like when using lift blocks on a spring over setup) creates an even bigger leverage to make more spring wrap.
so basically i think going from a SUA to a SOA creates more mechanical advantages that may cause noticable axle wrap/wheel hop.
<font color=red>3/4tonYJ</font color=red>
http://www.geocities.com/yj3qtr_ton
3/4tonYJ is offline
