Does any one know what all is needed to hook up the York for use on an ARB and for on board air? Help have a trail run tommorow and really would like to get this done....THANKS!
have you adapted a york to an ARB? if so where do I find a pressure cut off valve for the tank?? Or any tips to do a quick set up for this weekend and then we can do more intricate detailing like the diagram I found on the internet @ http://home.europa.com/~bateman/jeep/78cj5/mods/air/schem.gif ??
Thanks alot for your help
there is a pressure release valve on the backside of the york that keeps popping when the compressor clutch is engaged. Do I need to get rid of it, replace, or what???
yes i have in the past. now I have detriots. You need to buy a pressure switch, a check vavle and some kind of holding tank.
AFA this weekend...well it's hard. how the ARB works is, that it shots 85-105 psi of air into the locker and holds it there while it's engages. when you shut it off, it releases the air.
If you bought a portable air tank at you local parts store you could use that. Then went to a compressor store... like this one http://www.grainger.com/index.htm
You could get a pressure switch to regulate the pressure. don't worry about the check vavle now, you can get that later from the same place..
hope this helps
Rob
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
