I am thinking about replacing my tired old BBD with a Weber K551 this month. I've got a few questions for anyone that has done this. I have a 79 CJ7 with a 258 and a TH400 automatic transmission. Will the Weber work with the auto tranny (kickdown)? Is this a realatively easy conversion? Are the results worth the $350 price tag? Any words of advice, warnings, suggestions? Thanks
I likely still have my instructions. I recall a commercial web site exists too. I'll get back to you tomorrow with the info - need to scan it in case I don't find the web site address.
-Drew M.
Didn't find my old installation instructions - it pretty straight forward. Salient points are: install the adapter carb plate w/ Locktite to it doesn't vibrate loose (mine did 2x before Locktite) and make sure the throttle plates do not contact the carb adapter when at full throttle. Found a web site with tuning instructions (very handy) www.redline@redlineweber.com/idle_adjustment.htm
The weber installed fine with my 258 and TF999 auto. I don't see that there would be much difference in connecting the kickdown for your trans. It was a really simple install. i bought my Weber used and had no instructions and had no problem.
I would assume since it is a 79 w/TH400 it is the Quadratrac model. Same thing I have. I just recently installed this carb on my jeep. There is no kick down linkage to contend with on the TH400. Kickdown is controlled electrically by a gas pedal actuated switch.
IMHO, it was definitely worth the money. Idle is much smoother, easier starting, better pickup. Just all around better performance than the old BBD and my gas mileage increased by about 3mpg to boot.
Added website for tuning to old posting above. No txt.
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
