I'm looking for a Wagoneer non-lockup 727 to swaping into a CJ7 401/Dana 300. How do I tell a lockup trani from a non-lockup version? Thanks in advance.
-Drew M.
the lock up style has a short "nub" sticking out of the input shaft maybe .75 to an inch long, that is NOT SPLINED, and a hole in teh center that goes all the way back into the valve body
more on the "nub" its actually the very end of the inner input shaft ( not the reaction shaft) the farthest part sticking OUT of the bellhousing:
SMOOTH lockup
SPLINED NON LOCKUP
the NON lock up style, doesnt have anything like this, its splined all the way out. it has what appears to be a hole, but it doesnt go very far into the shaft
you can also tell from the valve bodys, if its out and youcan view the top of it, there is a aluminum tube, in the shape of an "S" almost going across the top of the valve body
this is also the tube you can splice a servo/valve into to disable the lockup function from inside the truck with a switch, or so ive read.
OzarkJeep
77 CJ5, in a bunch of sanded and primered pieces
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
