Survey: What axles are you running - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 05-02-2000, 04:56 AM
Re: Survey: What axles are you running
Currie 9" front and rear. Almost a shame to only have a six, but it's a very healthy six. Still, a couple more cylinders might be kinda nice.
post #12 of (permalink) Old 05-02-2000, 07:20 AM
elusive's Avatar
front is a scout dana 44 w/a detroit and 4.56 shortened 3 inches
rear is an AMC 20 with moser axles, detroit, 4.56
both seem pretty durable with 35X16 boggers and lots of horsepower
~~Elusive~~
it's sort of still a cj thingy....see it at www.jeepgod.net
elusive is offline
post #13 of (permalink) Old 05-02-2000, 07:34 AM
I Do This For The Glory
JEEPN's Avatar
Scrambler: Scout II D44's Front and rear, lockrights in both, 4.10's
After the 350 swap I plan on running D70 rear with full spool and D60 front with Detroit or ARB, both with low gears.
TJ: Stock, D35C (blown once already), D30, Trac-Lok, 3.55's.
Commando: D44 (flanged, stock) rear, D27 front, 3.73's. Will upgrade front to D30 (from Scrambler) and lock both.
Willys: stock running gear on both, will lock eventually.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7"Lift/33"TSL's/IHC D44's 4.10's Lock'd
JEEPN is offline
post #14 of (permalink) Old 05-02-2000, 08:18 AM
utahjeepr
Current: (f) Stock Dana 30- open w/ 5.38, (r) Stock D44 flanged- Detroit w/ 5.38
In the garage waiting for the parts fairy to bring final components:
(f) Dana 44 out of Dodge truck- narrowed, custom alloy axles, w/detroit and 5.38, (r) Dana 60 full floater out of Ford truck- narrowed, custom alloy axles, w/ either a spool or a detroit and 5.38
My other car is a BULLDOZER
post #15 of (permalink) Old 05-02-2000, 08:26 AM
I am still running the stock axles front and rear, 30 front with a power lock and 44 rear with a true track, 35"x12.5" BFG Mud Terrains. Have yet to break either one except from outside influence. The rear R&P went after two of the socket bolt heads popped off in the true track and went through the gears several times and out through the cover. The only problem with the front is when I was driving on the freeway with front only the next week while I was waiting on the new gear set for the rear and lost the vent hose and all of the oil. Other than that I have done no damage with ~400 lb-ft of torque available feeding a T-18 granny low. But I do tend to try and "crawl" an obstacle rather than hammer over it!
The Grim Jeeper!
post #16 of (permalink) Old 05-02-2000, 08:28 AM
I Have 78 F150 axles 9" rear (31 Spline) w/detiot 4:56's and rev.cut 44 front w/detriot 4:56's running 35's BFG muds
so far so good
Rob
post #17 of (permalink) Old 05-02-2000, 10:09 AM
98 TJ with Dana 35 and Dana 30. In the process of swapping to a Ford 9" in the rear.
Aaron
post #18 of (permalink) Old 05-02-2000, 10:37 AM
89 YJ, SOA 7" lift
Ford 8.8(95 Explorer)with disc brakes, Detroit locker, 4.56 gears.
Dana 30 front, with Warn Locking Hub kit, High strength axles,ARB Locker, 4.56.
Currently Building a Dana 44 from an 87 G.Wag, with knuckle over steering,ARB, 4.56
Jeff
89 Wrangler
If at first you dont succeed, your replacement will try and try again.
H8monday is offline
post #19 of (permalink) Old 05-02-2000, 10:59 AM
Scout rear 44 and J20 front 44, 4 discs, 2 detroits and 4.56 gears
Lee
[img]/wwwthreads_images/icons/laugh.gif[/img]
post #20 of (permalink) Old 05-02-2000, 11:30 AM
Narrowed 14-bolt with Detroit and Dutchman shafts in the rear.
Narrowed 8-lug D44 with Lock-Right and resplined stock shafts in the front.
I tried welded rear shafts and broke one which shattered a bunch of teeth on the first Detroit. (Lesson learned there.)
Jason '87YJ
(350/NP435/D300twinstick/SOA/GM14-FF-Detroit/D44-Lock-Right/M8274)
