Holley 4 barrel - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-01-2000, 01:31 AM
Holley 4 barrel
What would be the best way to disable the secondaries on a Holley 4 barrel? Thanks
The number on the carb is "6R 7809"
post #2 of (permalink) Old 05-01-2000, 10:37 AM
Re: Holley 4 barrel
Mechanical Secondaries or Vacuum Secondaries?
If you don't know, there is a list number on the air horn that houses the choke blade.
The list number will face the front float bowl.
Give me that list number, and I will give you the info on your carb...
Junk Yard Genius is offline
post #3 of (permalink) Old 05-01-2000, 04:37 PM
Re: Holley 4 barrel
Aaron, I believe the number is 6R-7809. Thanks again for the information..
post #4 of (permalink) Old 05-02-2000, 09:28 PM
Re: Holley 4 barrel
6R-7809 doesn't come back as a ligimate list number...
See the attached photo to double check the location of the list number...
post #5 of (permalink) Old 05-03-2000, 06:52 AM
Re: Holley 4 barrel
Oops[img]/wwwthreads_images/icons/blush.gif[/img] The number is 80457 Thanks a bunch[img]/wwwthreads_images/icons/crazy.gif[/img]
post #6 of (permalink) Old 05-03-2000, 01:58 PM
Re: Holley 4 barrel
Well Ken, Here we go...
Carb P/N (List)................................R-80457
Model .............................................4160
CFM............................................... 600
ReNew Kit .....................................37-119
Trick Kit..........................................37-933
Primary Needle & Seat ...................6-506
Secondary Needle & Seat ...............6-506
Primary Main Jet .............................122-69
Secondary Main Jet or Plate ............134-39
Primary Metering Block ..................134-128
Secondary Metering Plate ...............134-39
Primary Power Valve .....................125-65
Primary Discharge Nozzle .............. .031
Secondary Spring Color...................Black
Primary Bowl Gasket.......................108-83-2
Primary Metering Block Gasket........108-89-2
Secondary Bowl Gasket...................108-90-2
Secondary Metering Block Gasket...108-90-2
Secondary Metering Plate Gasket.....N/R
Primary Fuel Bowl...........................134-101
Secondary Fuel Bowl.......................134-105
Throttle Body & Shaft Ass...............N/S
Primary Venturi Diameter.................1-1/4"
Secondary Venturi Diameter............1-5/16"
Primary Throttle Bore Diameter.......1-9/16"
Secondary Throttle Bore Diameter...1-9/16"
Primary Acc. Pump Volume.............30CC
Secondary Acc. Pump Volume.........N/A
You might want to print this page out and keep it.
Not everyone has this info...
It helps to note any changes on this page so you know what has been done six months or a year from now...
post #7 of (permalink) Old 05-03-2000, 02:32 PM
Re: Holley 4 barrel
To answer your orignal question...
See the attached picture...
The secondaries of your carb are controlled by a vacuum diaphragm.
That diaphragm is normally located on the passenger's side of the vehicle, an slightly to the rear of the centerline of the carb.
The top cover is about the size of a silver dollar.
The diaphragm pull on an actuator rod.
That rod pulls the secondary throttle shaft that opens the throttle blades.
To remove the actuator rod from the secondary throttle shaft, you must remove a 'C' clip.
That 'C' clip is very small, and easily damaged, so be careful.
Once the 'C' clip is removed, remove the actuator rod from the shaft linkage.
The rod can just hang in space until you decide to hook it back up again.
This secondary throttle shaft linkage MUST be secured to prevent the secondaries from opening.
Use a wire or 'zip' tie to keep them shut...
Just out of sheer curiosity, Why the heck do you want to disable the secondaries for anyway?....
post #8 of (permalink) Old 05-03-2000, 02:46 PM
Re: Holley 4 barrel
The reason being that I am getting gallons per mile. I am very light on the foot and can't figure out why I'm getting $%^&*@ gas mileage[img]/wwwthreads_images/icons/frown.gif[/img]
post #9 of (permalink) Old 05-03-2000, 03:08 PM
Re: Holley 4 barrel
It could be a lot of things...
That carb has the power valve protection, so it's probably not a blown power valve...
I don't think unhooking the secondaries is going to help, but it might show a problem...
Did you buy the carb new, or did someone have a chance to fiddle with it before you got it?
Your bio says Washington...
Washington state or Washington D.C.?
post #10 of (permalink) Old 05-03-2000, 03:15 PM
Re: Holley 4 barrel
I have had this Jeep for over two years and no one has messed with the carb while I have had it. Possible rebuild issue, i.e. float level. I have heard that the newer Holley 4010/4011 series get really good mileage, up to 25 miles per gallon on Chevy 350? Do you know about these carb? If I have the motor turned off and sitting with the key on position for a few minute, when I try to start the engine it has a hard time starting.
