WHAT ARE THE CONSEQUENCES OF A "TOO LOW" FLOAT? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2000, 12:14 AM
WHAT ARE THE CONSEQUENCES OF A \"TOO LOW\" FLOAT?
TIA
jsjps
post #2 of (permalink) Old 04-30-2000, 08:52 AM
Re: WHAT ARE THE CONSEQUENCES OF A \"TOO LOW\" FLOAT?
[img]/wwwthreads_images/icons/smile.gif[/img] You will "starve out" the engine on acceleration, and you may not be able to get fuel to the idle jets. Sometimes the power jets will not work at all.[img]/wwwthreads_images/icons/crazy.gif[/img]
CJDave
Quadra-Trac modified by the crack moonguy[img]/wwwthreads_images/icons/wink.gif[/img][img]/wwwthreads_images/icons/smile.gif[/img][img]/wwwthreads_images/icons/tongue.gif[/img] transfer case team.
CJDave is offline
post #3 of (permalink) Old 04-30-2000, 10:45 AM
My edelbrock #1406 with off-road kit is set at 9/32 at rest and 1.25 drop. I got a 400 hp 350, does not stall or anything. I am going to experiment with different rest heights to see which works best, for my engine, when I get some time.
[img]/wwwthreads_images/icons/smile.gif[/img] 1976 CJ-7,CHEVY 350, 33'S, 3" LIFT, THAT COVERS MOST OF THE MAJOR STUFF [img]/wwwthreads_images/icons/cool.gif[/img]
post #4 of (permalink) Old 04-30-2000, 12:47 PM
Depends on what you mean by, "Too Low"...
And on what carb...
You will run lean on all counts.
If it's just, "a little low", then you will only be, "a little lean"....
Most carbs rely on the pressure that a column of fuel provides to allow the 'Jets' to flow correctly, and to keep a proper level of fuel in the mixing tubes inside the carb body.
If you make the column of fuel lighter, by lowering the float and fuel level, it will not flow through the 'jets' properly, and it will become lower in the mixing tubes also.
If you lower the floats enough the jets and emulsion tubes start drawing extra air, the mixture will become lean enough to actually do damage to the engine.
Why do you ask?
Aaron.
Junk Yard Genius is offline
