Removing Stick on antenna.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-07-2001, 11:28 AM
I used to have a scanner in my jeep that I have removed....
It used a "thru the glass, stick on type" antenna, the piece
that is on the outside is still stuck on, any ideas on how to remove it?
<font color=red> Red 7 </font color=red> in the <font color=green> Green Mountain State </font color=green>
<font color=red>84 CJ7 / 258 / weber
</font color=red>
torx: the root of all evil.
post #2 of (permalink) Old 06-07-2001, 11:52 AM
Re: Removing Stick on antenna....
You could use Jeepn's term and use the "Sledge and Tweak" method, but I would not recommend that.
Most of the glues used on glass are a form of SuperGlue. It's removable with acetone. The problem... getting the acetone to where the glue is.
Try a nice sharp pick (dental type) and pick away at some of the glue... and then start dripin' acetone into the area.
Or, try a nice sharp metal metal putty knife that you can use to slice the glue into submission. However, be careful... you can scratch the glass.
post #3 of (permalink) Old 06-07-2001, 11:52 AM
If it's just held with double sided stick foam like many are, a razor blade works great. The windows on Jeeps are so flat that it's near impossible to cause a scratch with it. If it's some sort of other adhesive, spray a little carb cleaner on it and let it sit for about a minute, then yank it off.
'88 Sahara, 4.2, auto, 4.0 head swap (finally), no trac bars.
post #4 of (permalink) Old 06-07-2001, 12:01 PM
Use a heat gun(or borrow your wifes/sisters/girfriends/mothers blowdrier) and heat the glass from the inside. That antenna will just about fall off.
jimmythetech is offline
post #5 of (permalink) Old 06-07-2001, 12:07 PM
I Do This For The Glory
JEEPN's Avatar
Just use a smaller sledge...
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 5" Calmini, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #6 of (permalink) Old 06-07-2001, 12:17 PM
Caver Dave's Avatar
Dang, you guys are SUBTLE!! I was gonna suggest "grab & jerk" method
Caver Dave
'68 Jeepster SW
225 & 3spd
Vintage Jeeps(ters) have Character,
new Jeeps just have payments.
Caver Dave is offline
post #7 of (permalink) Old 06-07-2001, 01:00 PM
Hooch's Avatar
Or replace the glass [img]/wwwthreads_images/icons/wink.gif[/img]
Hooch
'83 CJ-7 258/TR/TF999/D300 in Land Rover Country
Hooch is offline
post #8 of (permalink) Old 06-07-2001, 01:45 PM
Just be careful with that heat gun if you have any window tint close by...
82 Scrambler/360/T5/D300/4" SUA/AMC20/Rear Discs/Somers Bros Axles/D30/3:73's/Lockrite Lockers.
2001 Bare Stock Trendy Jeep Sport (everyday driver)
Smithville, Texas
Member TX4X4 Cyber Club
kerryp is offline
post #9 of (permalink) Old 06-07-2001, 01:51 PM
Pooh-Bah
pbmcauliffe's Avatar
I you end up using a razor blade to clean the residue off, keep the area wet with water or glass cleaner to help reduce scratching the glass, even if it's flat glass.
pbm
74 cj5,304,t18,2.46 ts d20,30f,44r,soa,MORE buggy front,35's,Rci's,5pt,full cage,air,etc.
78 J10,360,727,d20,44f,44r,35's,4" lift,etc.
<font color=red>Support Search and Rescue.......Get Lost!</font color=red>
pbmcauliffe is offline
