high oil pressure - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 07:15 PM
high oil pressure
I posted a while back that my oil pressure was too high. I was told that my PCV was plugged or that the CV tube would be plugged. I checked and they aren't plugged. What else could be causing this. The pressure is about 40 psi at an idle and sometimes gets as high as 50 when at high rpms. I am getting more oil leaks and Im afraid that if I cant figure out whats going on then I am going to blow more seals. Thanks for the help.
Jeep CJ6, 225 v6 buick, turbo 400, dana 18
post #2 of (permalink) Old 06-06-2001, 07:21 PM
Re: high oil pressure
50PSI is not that high! But if you are loking for something check the oil pump, there is a presure relief valve on it, it may have stuck (Not verry likely though!) Good Luck:
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's Mud's,Pony Carb...
CJ7JeepOffRoad is offline
post #3 of (permalink) Old 06-06-2001, 09:04 PM
I was told that I should have 35 psi at 2500 rpms. Should there be that big of a difference. If its not a big deal then thats great but I wasnt really sure. Thanks
post #4 of (permalink) Old 06-07-2001, 06:43 AM
yea 50psi should not give you any problems! Every motor runs different so there is no set pressure for the oil. As long as it does not go below 5psi and does not go over 100psi I would not worry about it! Are you having trouble with blowing seals?
Rodney C
