J10 T-18 in a CJ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 05:46 PM
J10 T-18 in a CJ?
I just picked up a 78 J10 4X4 with a (I assume) T-18 4 speed. Now I know these things had some kind of an adapter between the box and the bellhousing. The big question is will it work in a CJ or will the shifter be in the back seat? Also, whats up with that Xcase J shift pattern?
76 CJ5,2.5" lift/Rancho 9000's,258/T-177/D300,HEI,Offy,Locked F&R
post #2 of (permalink) Old 06-06-2001, 08:07 PM
Pooh-Bah
pbmcauliffe's Avatar
Re: J10 T-18 in a CJ?
Yes the dana 20 in it has a "J" shift pattern. Using the transmission and tcase directly out of the J10 would give you a rear shaft of about 12" long and a steep angle.
Do a search on it, it was covered a couple times in the last month about what needs to be changed. My T18 came from a Ford (so it was already short), and my J10 has a TF727, so can't look at that for help either.
pbm
74 cj5,304,t18,2.46 ts d20,30f,44r,soa,MORE buggy front,35's,Rci's,5pt,full cage,air,etc.
78 J10,360,727,d20,44f,44r,35's,4" lift,etc.
<font color=red>Support Search and Rescue.......Get Lost!</font color=red>
pbmcauliffe is offline
post #3 of (permalink) Old 06-06-2001, 08:14 PM
If the J10 had a 258, it would not have the adapter box on the front. Otherwise, if it does have the long shaft, you need to change the input shaft to a Ford as well as the bearing retainer and pilot bushing. These link do the long shaft swap:
http://www.offroaders.com/info/tech-...18-rebuild.htm
http://users.rcn.com/jeepfan/t18_swap.htm
-Jay
Denver, CO
1978 CJ-5 258 Weber, 'glass body
post #4 of (permalink) Old 06-07-2001, 07:03 PM
I thik I remember the FSJ T18 even behind a 6 cylinder had a longer input shaft than the Ford version ( approx 6.5 inches)
I know for a fact the FSJ V8 version T18 has LONG about 15 inch inpout shaft and a spacer.
IM thinking the 258 version is about 8 or 9 inches long with no adapter?
but that doesnt make much sense does it, hmmmm
maybe it is the short one, around 6.5 is the one you want to use a T150 bellhousing and get the shortest setup possible.
OzarkJeep
"Bare foot girls, dancing in the moon light..."
ozarkjeep is offline
post #5 of (permalink) Old 06-07-2001, 07:13 PM
I'm not sure if the J10 258/T-18 combo is uses the same length bellhousing as the CJ's, but I would assume it would. I have seen the Jeep T-18 inputs from a 258 and yes, they are a bit longer than the Ford T-18's by about an inch or so. They have a longer pilot tip and the pilot bushing goes way in the crank, similar or the same as the one for the T-150. The Ford T-18 requires the pilot bushing that sets out a bit further in the crank to accomodate the shorter shaft.
I can't say for sure though, because I haven't seen a J-10 258/T-18, but I have seen a CJ 258/T-18.
-Jay
Denver, CO
post #6 of (permalink) Old 06-07-2001, 08:02 PM
elusive's Avatar
jeepgod has a t-18 ans a d-20 in his cj-7 and the length is fine.. it does have about a 5" adapter in it, but the shifter is in a good place and the rear driveshaft is plenty long
~~Elusive~~
http://www.jeepgod.com
elusive is offline
post #7 of (permalink) Old 06-07-2001, 08:15 PM
The t-18 on the J10 has a 5" spacer in front of it, if you remove this spacer you will end up with a really long input shaf that will require swaping for a short version. Now if you are installing it on a cj-7 you can leave the spacer and you will have a rear drive shaft couple inches shorter which will be no real problem. Now if you are installing on a cj-5, then you will need to get the short input shaft.
junior
post #8 of (permalink) Old 06-07-2001, 08:45 PM
Actually closer inspection has revealed (I brought it home today) that the 6 cyl. vehicles have no spacer, just a bellhousing that is about 1 1/2" deeper than the CJ. Outta work.
post #9 of (permalink) Old 06-08-2001, 10:16 PM
I used a J10 T18 in my CJ in place of the t150. The T18 came from a 6 cylinder, 258 J10.
I bolted it up in place of the t150 without a problem. The input shafts on the t150 and T18
were exactly the same length. If you have a 258 in the J10 IT WILL bolt up just fine.
Alec
'78 CJ7 258 T18/dana 20...dana 30/amc 20 w/ mosers & lockrights...
'glass body w/ tied in full cage...warn x8000i
http://members.aol.com/fastflyn31/page1.html
Alec78CJ is offline
