CV Drive Shaft? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 02:36 PM Thread Starter
CV Drive Shaft?
I just got a D20 from a 72 Waggy and it has the CV front drive shaft attached! I am going to try to install the front CV into my rear driveshaft, Has any one tried this? I think the front and rear t-case yokes are the same? Should work? Thanks:
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's Mud's,Pony Carb...
CJ7JeepOffRoad is offline
post #2 of (permalink) Old 06-06-2001, 02:55 PM
Re: CV Drive Shaft?
It depends on the brand of CV drive shaft. Most likely you will need a different output yoke on your transfer case. On mine, they look exactly the same but they are just different enough to require the different yoke. I would suggest 6 States Dist for the yoke unless you have a local drive train shop.
John...southern CA
84CJ7, 3"lift, 32"BFG, 4.10's, ARB Rear, Detroit Front, Solid Axle's, Durabak, York Air
They say we learn by our mistakes......I guess thats why we are all so smart.
post #3 of (permalink) Old 06-06-2001, 09:36 PM
Official Historian
WILL's Avatar
Re: CV Drive Shaft?
The front and rear yokes should both be 10 spline. The parts catalog shows them as being the same front and rear on a cj which means no cv. But if you get another cv yoke, you can bolt it on the rear output and use a cv driveshaft.
79/CJ-7/AMC360/TH400/Q-TRAC/d30/d44/33's/RS9000s/Herculiner/Pro-jection 2D/MSD/4.10s/lockrights
WILL is offline
post #4 of (permalink) Old 06-07-2001, 08:35 AM
Re: CV Drive Shaft?
We've done this one a couple times. If you're bolting this to a D300 you need a fine 23 spline yoke. One from a late 79 and newer Q-trac waggy(front) will do. The yoke is about $48 new. For D20 the 10 spline; early 79 waggy and older, works. Our shop will shorten and balance for $50, its a bargain upgrade.
76 CJ5,2.5" lift/Rancho 9000's,258/T-177/D300,HEI,Offy,Locked F&R
