Joint at steering box end loose - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 10:33 AM Thread Starter
The joint at the bottom of the steering shaft on my 84 CJ7 seems to be loose and the boot has torn again. Is there any way to replace this joint with another kind of joint like a u - joint on the borgeson shafts? Or can I replace it with another factory joint? I'm too cheap to buy the complete borgeson shaft as I feel it's only the bottomthat's causing me a problem right now. How does the borgeson shaft make up for changes in lenght of the shaft as the body moves on it's mounts? The factory joint seems to have a small amount of in and out play built into it's design.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, Lockright, full cage & belts, Xenon flares, AMC 20 1pc axles, GM dual diaphragm brake booster
TiminMb is offline
post #2 of (permalink) Old 06-06-2001, 11:03 AM
Re: Joint at steering box end loose
Tim,
The borgeson shaft is a tight slip fit between the two sections that allows for a few inches of play. I should have measuered mine before I put it in.
Tony
http://www.wilhelm-tech.com/jeep
post #3 of (permalink) Old 06-06-2001, 11:59 AM
The joint itself is available but you have to weld it on to your existing shaft. You also have to make sure that you weld it on straight or it could bind.
jimmythetech is offline
post #4 of (permalink) Old 06-06-2001, 12:10 PM
I'm interested in the same thing. Do you get the joint from borgeson?
post #5 of (permalink) Old 06-06-2001, 12:12 PM
I'm not sure whereyou can get them, I have seen them hanging up in the local 4x4shop. I'm going there to price some swampers today so I'll try and find out where he gets them.
post #6 of (permalink) Old 06-06-2001, 12:20 PM
If I remeber correctly the joint from borgeson alone costs over $60. I was going to get a spare until I decided which steering box to use.
Tony
post #7 of (permalink) Old 06-06-2001, 01:49 PM Thread Starter
Just found this source of borgeson joints for pretty well any application;
http://www.freedomstreetrods.com/borgeson.htm#gmbp
TiminMb is offline
post #8 of (permalink) Old 06-06-2001, 01:55 PM
jeepfiend
Clicky [img]/wwwthreads_images/icons/cool.gif[/img]http://www.freedomstreetrods.com/borgeson.htm#gmbp
Cage Up, Wheels Down
Jeepfiend
All my Jeeps are in pieces!
