Bolt Replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2001, 09:41 PM
Bolt Replacement
I think I have the replacement scheme figured out for the broken off steering bolts. A piece of 1/4" flat steel with a new nut welded to it. What do you think. Will this hold the steering assembly on? Or should I go with a piece of 1/2" bar stock and just tap a new hole into it? Also, If I had to slightly enlarge one of the holes on the side of the frame to fit the piece in, would this severely weaken the frame? I saw the post where the guy cut a hole, welded new nuts and patched it. I am trying to avoid this. Thanks
'85 CJ7 Bone Stock, in pieces
post #2 of (permalink) Old 06-05-2001, 09:48 PM
Re: Bolt Replacement
I considered all the options when I had to fix mine, but after messing around for a while with it we decided that the easiest fix was doing a little cutting. It actually involved just cutting out between 2 holes, bending the piece down, welding the nuts in, and bending the piece back up and welding it. Unless you look close, you can't even tell what was done.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
