Redline gear lube - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2001, 06:45 PM
Redline gear lube
Hi all, just a quick question on gear lube. I have a 99 TJ, dana30/35. Am changing the diff oil out with Redline 75w-90. The manual specs 80w-90 for these diffs, and was wondering if there could be any problem using the lower viscosity. I suspect many TJs are running this lube, but just wanted to check. Am in Southern Ca., so we dont have much temp extremes. Thanks in advance.
Matt
post #2 of (permalink) Old 06-05-2001, 08:48 PM
I Do This For The Glory
JEEPN's Avatar
Re: Redline gear lube
Been running Mobil-1 75W-90 in the TJ for 60K now with no problems, in all temperature extremes.
JEEPN
Winter Harbor, Maine
'88.5 Zuki, 5" Calmini, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #3 of (permalink) Old 06-05-2001, 08:58 PM
You cant go wrong with the Redline stuff. Its as good as it gets.
I use 75-90 Mobil 1 Synthetic.
Jeff
89 YJ
Wow, you can get a nice tan on your arms, from welding with no shirt on.
H8monday is offline
post #4 of (permalink) Old 06-05-2001, 09:34 PM
Actually, the viscosity between the 75w-90 and 80w-90 is the same...they are both a 90 weight gear lube. While the 75w obviously means it can be used in a cooler setting, both lubes have to pass the API rating for a 90 weight gear oil. Use either Mobile 1 or Amsoil, and you should have no problems and get the best performance.
--Digger--
http://www.users.qwest.net/~ascanlon
