Steering gear box leaking: is it a Saginaw on CJ? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2001, 12:29 PM
Everything is finally fixed on my CJ7 except the steering box. It always had a small leak, and a little slop, but lately it's been leaking like a siv.
Is this a saginaw box, and can I replace it with anything from a junk yard, or do I need to get the $200-300 replacement from 4Wheel Drive Hardware, etc.
All suggestions needed! I'm going through a quart of power steering fluid every few days.
Jed
80 CJ7 258w/TR,Holley carb,5" lift,33x12.5's.
post #2 of (permalink) Old 06-05-2001, 02:26 PM
Re: Steering gear box leaking: is it a Saginaw on CJ?
Hey Jed,
I had the same problem on my CJ, and replaced it with an AGR SBII. You can get them for $350 at http://www.jimsoffroadwarehouse.com. It drives like a dream now, super tight, no slop, very responsive. I like it so much I'm also replacing my stock pump (no problems currently) with an AGR just to see what it will do.
In the way of a junkyard core, I've heard tell of using a Cadillac box, but not sure what's involved. Do a search here or over at http://www.pirate4x4.com/cgi-bin/ubb...?ubb=forum&f=4 to see if you can find the person who did the swap.
bluseman2a is offline
post #3 of (permalink) Old 06-05-2001, 03:48 PM
I had mine totally rebuilt last year after it started leaking, cost $170 and boy does it steer better now (and doesn't leak either). With a junkyard box, you never know how much life is left in it.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #4 of (permalink) Old 06-05-2001, 05:20 PM
jps4ever's Avatar
I put a caddy box on my jeep and it was a bolt on deal except grinding a small tit off the steering output shaft on the box. I got my rebuilt box at O'Rileys for $125 and it comes with a life time replacement. Order one for a 1976 Coupe Deville. The caddy box used the flare type hoses like on my 79, later jeeps used the o-ring hoses, easy to swap over. The caddy box has the bigger piston like the AGR and it makes my jeep steer really nice. A great swap for me!
Its a Ford, Chevy, Scout, Caddy sort of a thing.
jps4ever is offline
post #5 of (permalink) Old 06-05-2001, 05:51 PM
I just replaced the steering box on my 83 CJ-8 (had o-ring fittings). I used a steering box from an 87 Camaro.
Here's a link to the collection of info I have on the swap.
http://wilhelm-tech.com/jeep/mods/steering.htm
Is it just me or were the hose a real PITA to get on?
Tony
post #6 of (permalink) Old 06-06-2001, 06:48 AM
Thanks, guys. I won't go the junk yard route now; maybe I'll check into a Caddy swap, though. That might be easy to get here in the midwest. Will definatly look into getting a new one, though. Mine has play all over the place.
Jed
