anybody use bumpstop extensions? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-04-2001, 09:58 PM
sas87yj
to keep rear tires from rubbing instead of cutting body or adding body lift?
who makes them?
thanks
steve
87yj,6cly,5spd(ba10[img]/wwwthreads_images/icons/frown.gif[/img]),4.5"RE lift,SYE,CV,32x11.50MTR's,D30,D35posi
post #2 of (permalink) Old 06-04-2001, 10:44 PM
Re: anybody use bumpstop extensions?
I thought about making my own for the same reason. My tires hit my inner fenders quite hard sometimes.
Jeeplvr
http:// www.trailhed.com
Jeeplvr is offline
post #3 of (permalink) Old 06-04-2001, 10:59 PM
sas87yj
yeah i'm sure you could make some. i've seen pics of a couple different kinds but need to find a vendor. yjason said he has some along with a 2" body lift. he's running 35's.
steve
post #4 of (permalink) Old 06-05-2001, 03:06 AM
89yjsahara
I have some that came with my lift, they are the type that attach to the axle via the U bolts.. they don't like to stay upright most of the time, but I don't worry about them anymore, I just let the tire rub.. it aint that big of a deal..
Scott<><
89 yj sahara with trail stuff, 6" of lift, 35x12.50 BFG MT's on 15x8 AR 767's! http://www.Sonsofthunder4x4.com
post #5 of (permalink) Old 06-05-2001, 05:45 AM
Had some bump stops come with my 3in lift on a 94YJ. With 33's they don't do a thing. Tire hits before bump stop. So if you do make them make sure your measurements are accurate. On my 94 the bumpstops also hit a piece of rubber mounted to the frame so I'd take into account how soft the rubber is/isn't.
I love my country, but fear my government
post #6 of (permalink) Old 06-05-2001, 06:42 AM
sas87yj
sahara-
yeah i don't like the sounds of a bumpstop attached to the u-bolts. i am leaning towards an extension or "block" if you will placed between the existing stock rubber bumpstop and the frame. so your 35's rub a little with the 6" susp lift? front and rear or just rear?
thanks
steve
post #7 of (permalink) Old 06-05-2001, 06:47 AM
sas87yj
pierced-
sounds like your bumpstop extentions mounted on the axle and attached to the u-bolts? never seen these but am trying to visualize unless that is the design yjason showed me? yeah i was thinking about the dims being "critical" as far as them stopping the articulation before tire hits body. that's why making them could be a good idea- cost and first attempt may not work. the "piece" of rubber you speak of mounted to the frame is your "stock" bumpstop i believe.
thanks
steve
post #8 of (permalink) Old 06-05-2001, 06:53 AM
m715's Avatar
For my rear bumpstop I just ended up using the stock ones with a piece of 2"x4" rectangular box as the extension, I was going to buy some long bumpstops but they are $$$ and this was free So far its worked fine...
http://www.cj7jeep.com/suspension/misc.html
Luke
'77 CJ7 SOA Chevy 327
m715 is offline
post #9 of (permalink) Old 06-05-2001, 09:04 AM
m715 has the right idea. 3 years ago I made 1" extensions out of 1" square tubing and longer bolts, cost about 50cents and works fine.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #10 of (permalink) Old 06-05-2001, 10:31 AM
Now that I think about it using that extension trick, with the square. Is the way to go. I only used mine b/c I already had them. You could make them just as high as you need with them. I would do some fender trimming first though.
Jason
<font color=green>----------------</font color=green>
<font color=green>[]llll[] '90 YJ</font color=green> & <font color=blue>'88 Grand Waggie</font color=blue>
