shackle lift - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-03-2001, 11:01 PM
Joker2002
shackle lift
I am about to install 31x12.50/R15s on my stock 15x8 rims. My 93 Wrangler Renegade has no sort of lift whatsoever. I know that 31s will fit safely into the fender wells as long as no heavy-duty off-roading is going on, but I just want to make sure I have enough clearance. I am thinking about going with a shackle lift because it's a relatively cheap way to gain just one more inch of needed lift. However, even if I only raise my Jeep 1 to 1.5", would I still need new shocks to adjust for the change, or should the ones I have now (designed for no lift) still work?
Joker2002
'93 Wrangler Renegade / 4.0L
post #2 of (permalink) Old 06-04-2001, 01:27 AM
tdog90yj
Re: shackle lift
I would shy away from the shackle lift as to the front end alignment problems it can produce So if you are goping small a one inch body lift cant be beat. Esspecially if you are going to upgrade to say 33's in the future. Itll give you a little more flex room. Also be careful that the backspacing/offset with that size tire will work with your stock rims.
just my thoughts
Travis
90 YJ I6 258 4.0 head conversion 4"lift 33's & lots of other goodies
post #3 of (permalink) Old 06-04-2001, 07:02 AM
Re: shackle lift
ditto that last one. i squeezed 31. 10.50's on stock wrangler rims, with a body lift only, and i get some pretty good rubbage when turning hard. works good at the dragstrip though.
J ust
E mpty
E very
P ocket
yjdave is offline
