Anyone useing the front rollcage from Smittybilt? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-02-2001, 09:13 PM
Wondering if anyone outhere is using this front cage. Are the usual problems there (e-brake and window crank.How about leg room)?
I will be welding it to the frame and anchor it to the existing rollbar. Just want to know what others that have this one, think about it and what I should change before the final install
Thanks as always
Chu
[email protected]
YJ-7
HEI, 32/36, stump puller clutch,
44/30 axles both geared and locked
Warn axles, 8274, T-18, 35 MT/Rs, York set-up, ect...
post #2 of (permalink) Old 06-02-2001, 09:19 PM
Re: Anyone useing the front rollcage from Smittybilt?
I've had one since last summer. No problem with the e-brake, I had to move my glove box door over about a half inch. No restriction on leg room. Fit very well.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #3 of (permalink) Old 06-03-2001, 03:45 AM
I can get to the e brake, but its really tight. I also cut down the window cranks so I can open the windows without having to open the door first. As far as welding it to the frame, you will have to make some angled tubing or brackets, since the front hoop is 4 to 6 inches outside the frame rails. (assuming this is all going to be done on a CJ-7)
TJ
teejay68 is offline
post #4 of (permalink) Old 06-03-2001, 08:25 PM
Back to the top
Chu
[email protected]
YJ-7
post #5 of (permalink) Old 06-03-2001, 08:26 PM
Re: Anyone using the front rollcage from Smittybilt?
Do you happen to have pics on hand?
Chu
[email protected]
YJ-7
post #6 of (permalink) Old 06-03-2001, 09:53 PM
Here's a pic, hope this helps.
Brad
post #7 of (permalink) Old 06-03-2001, 10:00 PM
I can try to take some on monday, and post them for you. I assume your looking for the brake, and window areas?
tj
teejay68 is offline
