DANA 60 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-26-2000, 01:29 PM
DANA 60
what are your guys thougths on dana 60's? in my endless seach for better axles i have come across several of them. i understand that they are pretty beefy axles..but how much of a benefit would i gain from having dana 6o's? my main concern is loosing to much ground clearance and will drag the diff over everything. i will only be running 35's..is that enough clearance or is it just better to put dana 44's front and rear. can i use dana 60's front and rear out of a ford. or should i just use a 60 rear, and a 44 front.?
81 cj-7,360,SOA,35's,locked rear,fullcage
post #2 of (permalink) Old 04-26-2000, 02:11 PM
elusive's Avatar
Re: DANA 60
most fords diff would be on the wrong side for a cj
the 60 only hangs down an inch lower than a 44
~~Elusive~~
it's sort of still a cj thingy....
elusive is offline
post #3 of (permalink) Old 04-26-2000, 02:13 PM
Re: DANA 60
3/4tonyj has done the swap, looks great. You can check it out on his page, can't seem to find the url, maybe somebody else has
it, or better yet if 3/4ton is still hanging around.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
post #4 of (permalink) Old 04-26-2000, 02:18 PM
TOM85CJ7's Avatar
TOM85CJ7 is offline
post #5 of (permalink) Old 04-26-2000, 03:23 PM
Re: DANA 60
Am running a 60 in my TJ. See the article on my web site at:
http://www.hal-pc.org/~chartr/Dana60.html
if you want to read it. Lots of b.s. in there, but some facts too. It is not on my CBrack web site and there is no link from there either.
Doug '97 TJ
Creator of the CBrack
CBrack.com
post #6 of (permalink) Old 04-26-2000, 04:01 PM
I Do This For The Glory
JEEPN's Avatar
Re: DANA 60
How does the D60 clearance compare to the D70? How about the 14 Bolt? I'm thinking about upgrading again at a later date (after the 350, doubler, and 38" Boggers). I was going to run D60 front, with Detroit or ARB, but was thinking D70 or 14 Bolt for the rear, with full spool.
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7"Lift/33"TSL's/IHC D44's 4.10's Lock'd
JEEPN is offline
post #7 of (permalink) Old 04-26-2000, 04:43 PM
Re: DANA 60
i just came across a dana 60 out of a 3/4 ton GM, it has 4.56's and is full floating for 300$ is this a good axle to put under my cj? and is it a good price?
post #8 of (permalink) Old 04-26-2000, 04:55 PM
Re: DANA 60
blackcj, that full floater D60 you saw, I'll bet it's an 8 lug bolt unit. Before you buy make sure you can change it to a 5 on 5 1/2.
Gary
post #9 of (permalink) Old 04-26-2000, 05:11 PM
Re: DANA 60
the gm ff dana 60 is an 8 lug, is there a way i can change that, like take it to a machine shop and have them change the bolt pattern, or i recall some one offering a kit that changes 8 bolts to 5 or vice versa...
post #10 of (permalink) Old 04-26-2000, 05:37 PM
jeepgod's Avatar
Re: DANA 60
well i will be running a d60 out of a pre 74 jeep pickup.. its semi floating .. with 35 splines.. 1 and half inch axles... and its already 5 on 5 and half.. all pre 74 jeeps are.. mine was out of the 1/2 ton.. with a heavy duty option.. but the 3/4 and 1 tons came with it stock.. 1/2 usually had d44's front and rear.. infact will be putting it under the jeep friday.. just got it painted and cleaned today.. put together tomorrow.. they also came with 4.10's..
survival is instinct, but living takes guts
jeepgod is offline
